'06 alternator problems?
Old 03-18-2011, 05:31 PM
shima's Avatar
Everyday when I start my truck cold in the morning, the alternator gauge drops down and my lights dim. Then the gauge needle climbs back up and the lights go bright. This happens a couple times every morning. I recently heard a funny high pitch rattle noise that sounded like it came from the alternator at idle after I drove home the other night. Has anyone had an alternator go bad and have these symptoms? Thanks, Shima
Old 03-18-2011, 05:36 PM
annabelle's Avatar
Normal.....just the grid heaters cycling.
Old 03-19-2011, 06:07 AM
Jeff in TD's Avatar
Ditto. The grid heaters pull huge amps and dim the lights and drop voltage reading as they cycle. Don't know about the high pitched rattle noise.
Old 03-19-2011, 10:26 AM
06RAM2500's Avatar
Sounds like a bearing going out. Remove the belt, and feel the for resistance while you spin the rotor. There is a website that carries new bearings (front and rear) and new brushes for $35. I found that out after I bought a new alternator from the dealer for $350.
Old 03-19-2011, 03:09 PM
tryNto's Avatar
How about a link to said Website...
Old 03-19-2011, 10:52 PM
S.TX.MEGA's Avatar
I had a high pitched rattling noise in that area a couple of weeks ago and it was the water pump going out. it is right under the alternator.
5.9Excursion
03-13-2008 07:08 AM
jeeptjstud
12-16-2007 11:41 PM
Mike Holmen
11-12-2005 09:49 PM
Sonora Bob
12-10-2003 09:06 PM
poolboy
12-20-2002 10:25 PM
Quick Reply: '06 alternator problems?
