'03 cummins vs. '04.5
Old Jun 28, 2007 | 09:04 AM
ryan88's Avatar
I just bought an '03 6 speed cummins HO and i was wondering if it was the same motor as in the '04.5 -'05 as far as putting performance parts on it. and if not what are the differences.
Old Jun 28, 2007 | 09:09 AM
morkable's Avatar
For the most part they are the same,, you have to watch what you are buying however as there are somethings that just done work between the 2
Kevin
Old Jun 28, 2007 | 09:24 AM
ryan88's Avatar
Kevin
Thanks, do u know what the major differences are and if i could put an '04.5 exhaust kit on it
Old Jun 28, 2007 | 09:28 AM
baersmokers's Avatar
exhaust elbows are not the same size i found out the fun way
Old Jun 28, 2007 | 09:36 AM
soulezoo's Avatar
DTR 1st Sergeant
I think 4.5 and up is when they got the 3rd injector event, oil cooling on the pistons and some small physical changes like electric wastegate control vs. mechanical. Mentioned above is the different exhaust elbow. (3.5" vs 4")The biggie is a completely different ecm that makes it easier to get big power with just downloaders/modules. If you are looking at big power, once you get to a certain level of mods-- then the differences are insignificant.
Old Jun 28, 2007 | 10:21 AM
duallydave's Avatar
also you will get better milage from a 03-early 04.
andyboland
21
Jan 8, 2020 11:32 PM
mullishacrew
Feb 25, 2011 08:07 PM
12PACK
May 2, 2005 07:13 AM
ChrisLib
Dec 28, 2004 08:51 AM
ProjectM880
Dec 1, 2004 06:40 PM
