01 ho 6 speed?
Old 05-09-2006, 05:27 PM
jayjma20's Avatar
01 ho 6 speed?
hey i'm looking ast gettting a 01 6spd ho 3500 dually, is there anything i should be concerned with or checking into?
Old 05-09-2006, 11:24 PM
GlennRMK's Avatar
53 block and get fuel pressure checked
Old 05-09-2006, 11:44 PM
Ph4tty's Avatar
What he said + cycle the key three times and leave on without starting to read codes on an 01-02. P0216 = $1500
Old 05-10-2006, 04:06 PM
caleb c.'s Avatar
I don't think you need to worry about a 53 block in a '01.
Old 05-10-2006, 05:14 PM
jayjma20's Avatar
what is the 53 block? sorry i'm still fairly new to all this.
Old 05-11-2006, 11:46 AM
johnh's Avatar
6spd
some of the early six speeds had inferior syncro`s,if you can , ck the condition of the lube in the trans,,,if it looks like it has a lot of brass in it then it may need new synchro rings to fix it is not cheap. mine cost about $1900
Old 05-11-2006, 11:48 AM
johnh's Avatar
53 block
don`t count on it!!!!
Old 05-11-2006, 07:10 PM
GlennRMK's Avatar
Supposively, it is possible to get the 53 block on an 01. Especially an early 01. I've looked at 4 or 5 01.5s and none had the 53. All the 98, 99 and 00s I saw did have the 53 block.
Also, I thought the NV5600 didn't use brass synchros? Thought the 5 speed did. Been told the the 6 speed uses synchros that look like a motorcycle clutch disc?
Old 05-12-2006, 08:24 AM
BOILERMAKER's Avatar
It is possible to get a 53 in an 01 .................... I've got one. LOL
Old 05-12-2006, 08:34 AM
4x4dually's Avatar
My 02 6 speed had brass synchros. I can tell you this because the reverse went out at about 30,000 and I help all two thousand piece in my hand....pieces of crap.....
faster_than_ford
33
03-05-2004 07:24 PM
Sonny
02-15-2004 11:47 PM
SilverDodge
02-02-2004 05:56 PM
Mrcummins24
19
10-01-2003 11:43 AM
KC
01-10-2003 11:25 PM
Quick Reply: 01 ho 6 speed?
