1982 Dodge CTD 5spd
Old 04-19-2011, 02:54 PM
gyman98's Avatar
1982 Dodge crew CTD 5spd
Another crew in progress, hopefully with enough time (and money) it will be as nice as some of these ones on here.
Here's getting it home last summer, 2800km round trip from Kamloops, B.C:
Getting boosted by the donor truck
Stripped the ladder rack off and bolted on 3rd gen wheels
Donor runs for the last time:
Old 04-19-2011, 02:57 PM
gyman98's Avatar
Crew comes in:
Old 04-19-2011, 03:02 PM
gyman98's Avatar
'92 D60 with 3:55's bolts in with 4" skyjacker lift
Rear diff goes in with skyjacker add a leaf and salvaged air bags off a superduty
Getting engine ready for paint, valves and turbo swap
Old 04-19-2011, 03:07 PM
gyman98's Avatar
rear window and front doors come off
Moving the electrical bulkhead over to miss the clutch
Old 04-19-2011, 03:16 PM
gyman98's Avatar
Setting valves
HX35 vs H1C
In it goes
Old 04-19-2011, 03:21 PM
gyman98's Avatar
Bolted down, trans X-member is notched and installed. Underhood wiring well underway, steering coloumn, front brakes installed.
Old 04-19-2011, 03:24 PM
gyman98's Avatar
Link to the photobucket album with many more pictures
http://s222.photobucket.com/albums/d...%20crew%20cab/
Old 04-19-2011, 03:28 PM
Received 1,332 Likes on 862 Posts
Did I see that Crewcab on the Salmon Arm BC Craigslist?
Looking good so far! Thanks for the pics and updates.
Old 04-19-2011, 03:34 PM
gyman98's Avatar
Possibly, I've owned it for about 8 months now. There is at least one more identical to this one, both were ex-Alberta forestry trucks.
Old 04-19-2011, 03:56 PM
BTW I got my crewcab from Kamloops BC as well. Over on the North shore.
Old 04-19-2011, 06:04 PM
Featherman's Avatar
Hey Ashley.....................looking good. Can hardly wait for the finished product. We'll have to meet halfway for coffee or something!!!
Is that Hemi orange?
With the 4 inch lift, what are planning for tires and wheels?
Ron
Old 04-19-2011, 06:34 PM
gyman98's Avatar
They seem to weather quite well out there, mine is very solid.
Ron
Hey Ron, coffee half way sounds good and thanks for the compliment means a lot coming from a guy that built one of the nicest ones out there.
Its Chrysler orange which is very close to C5 ford/arctic cat orange which will be part of the exterior.
Going with 35x12.5x17 tires mounted on ATX artillery chrome wheels. Tires will either be kumho venture Mt's or Toyo open country Mt's
Old 04-19-2011, 11:21 PM
gyman98's Avatar
Drilled out for the LE door wiring
Did some more work in the engine bay
Old 04-24-2011, 11:31 PM
gyman98's Avatar
Used a right angle drill to attach the clutch bracket, worked perfectly.
The old gas tank
New tank installed, had to use heat to re-mold the top of the tank to avoid conflicting with the cab. Also dropped the tank 1/2" to help clearance. Redrilled mount holes on the front bracket and molded a plastic shim for the back bracket to drop it.
Stripped down the rad support while waiting for help to hang the doors today, did get the LE doors hung but no pictures yet. Tried to install front driveshaft but the 5spd shaft I bought turned out to be for a auto. Tried to install new rear carrier bearing but had the wrong size, always something!
Old 05-11-2011, 11:18 PM
gyman98's Avatar
Painted a few intercooler brackets and a few other things
Painted the dash
Installing new heater core into the 82 box with the 92 lid. Cut the lid to install the 92 resistor into the box and the 92 heater motor
Quick Reply: 1982 Dodge CTD 5spd
