1982 Dodge crew CTD 5spd
5 Attachment(s)
Another crew in progress, hopefully with enough time (and money) it will be as nice as some of these ones on here.
Here's getting it home last summer, 2800km round trip from Kamloops, B.C: Getting boosted by the donor truck Attachment 63631 Stripped the ladder rack off and bolted on 3rd gen wheels Attachment 63632 Donor runs for the last time: Attachment 63633 Attachment 63634 Attachment 63635 |
5 Attachment(s)
5 Attachment(s)
'92 D60 with 3:55's bolts in with 4" skyjacker lift
Attachment 63621 Rear diff goes in with skyjacker add a leaf and salvaged air bags off a superduty Attachment 63622 Attachment 63623 Attachment 63624 Getting engine ready for paint, valves and turbo swap Attachment 63625 |
7 Attachment(s)
Attachment 63614
Attachment 63615 rear window and front doors come off Attachment 63616 Attachment 63617 Moving the electrical bulkhead over to miss the clutch Attachment 63618 Attachment 63619 Attachment 63620 |
4 Attachment(s)
Setting valves
Attachment 63610 HX35 vs H1C Attachment 63611 Attachment 63612 In it goes Attachment 63613 |
1 Attachment(s)
Bolted down, trans X-member is notched and installed. Underhood wiring well underway, steering coloumn, front brakes installed.
Attachment 63609 |
Link to the photobucket album with many more pictures
http://s222.photobucket.com/albums/d...%20crew%20cab/ |
Did I see that Crewcab on the Salmon Arm BC Craigslist?
Looking good so far! Thanks for the pics and updates. |
(Post 2957707)
Looking good so far! Thanks for the pics and updates. Possibly, I've owned it for about 8 months now. There is at least one more identical to this one, both were ex-Alberta forestry trucks. |
BTW I got my crewcab from Kamloops BC as well. Over on the North shore.
Hey Ashley.....................looking good. Can hardly wait for the finished product. We'll have to meet halfway for coffee or something!!!
Is that Hemi orange? With the 4 inch lift, what are planning for tires and wheels? Ron |
(Post 2957721)
Originally Posted by Featherman
(Post 2957756)
Is that Hemi orange? With the 4 inch lift, what are planning for tires and wheels? Ron Its Chrysler orange which is very close to C5 ford/arctic cat orange which will be part of the exterior. Going with 35x12.5x17 tires mounted on ATX artillery chrome wheels. Tires will either be kumho venture Mt's or Toyo open country Mt's |
4 Attachment(s)
Drilled out for the LE door wiring
Attachment 63596 Attachment 63597 Did some more work in the engine bay Attachment 63598 Attachment 63599 |
5 Attachment(s)
Used a right angle drill to attach the clutch bracket, worked perfectly.
Attachment 63529 The old gas tank Attachment 63530 New tank installed, had to use heat to re-mold the top of the tank to avoid conflicting with the cab. Also dropped the tank 1/2" to help clearance. Redrilled mount holes on the front bracket and molded a plastic shim for the back bracket to drop it. Attachment 63531 Attachment 63532 Stripped down the rad support while waiting for help to hang the doors today, did get the LE doors hung but no pictures yet. Tried to install front driveshaft but the 5spd shaft I bought turned out to be for a auto. Tried to install new rear carrier bearing but had the wrong size, always something! Attachment 63533 |
6 Attachment(s)
Painted a few intercooler brackets and a few other things
Attachment 63229 Painted the dash Attachment 63230 Attachment 63231 Attachment 63232 Attachment 63233 Installing new heater core into the 82 box with the 92 lid. Cut the lid to install the 92 resistor into the box and the 92 heater motor Attachment 63234 |
