Wanted Put your WANTED items here.
Mark this thread as Unsold
Clutch assembly
Old Aug 20, 2022 | 12:51 PM
MoPowa's Avatar
72-93 Clutch assembly
Looking for the entire clutch assembly for an early first gen. I assume they are all the same from 72-93.
Firewall bracket, pedal, rod. Do not need the master.
Thanks
Am in Canada.
Old Aug 24, 2022 | 07:29 AM
The earlier clutch pedals have a rod that moves the Z-bar that open the clutch fork up.
About '88 they go to using clutch hydraulics, which changes the whole design of the pedals, fire wall bracket / hole, ETC.
It might be easier to find one or the other set up depending on what you are working on.
I know I have a few of the '88-'93 style pedal assemblies in my shop.
Old Aug 24, 2022 | 12:05 PM
MoPowa's Avatar
Good to know.
Sounds like the post 88 is what I need then. Am using hydraulic, will be modifying the rod to an f550 clutch master for the zf6 in my 89.
What do you want for the assembly (peddle, bracket, rod) Oliver?
Old Aug 25, 2022 | 04:44 PM
I sent you a PM about some parts.
juggernautt
Wanted
Feb 11, 2018 07:30 AM
steveinaz
Wanted
0
May 25, 2015 07:54 PM
12valvedutchy
Aug 23, 2009 09:47 PM
mhuppertz
May 26, 2006 04:08 PM
