TXDTR #8: October Meet
Your wish has been granted!
Either i had bad batts or these Optima Yellow tops i just put in are freaking awesome! I started my truck for the first time after putting them in (Wife been driving the rig as of late) and it was like it was almost ticked off i tured the key...i mean it JUMPED to life! I guess 1400 CCA's make a big differance...i was honestly suprised! I highly recomend......
"Clicking off" the stud nuts to check torque is usually fine, but for a proper (OCD
) re-torque the nuts must be backed off and bearing surfaces must be re-lubed... that's the 100% way to establish correct clamp load after heat cycling has allowed the studs to stretch.Anything less and there's a risk of compromising HG seal integrity at higher power levels; the stud/HG(O-ring) clamp relationship is important - have to match torque to O-ring protrusion, so the clamp load can be balanced between the HG's fire ring for cylinder pressure and the steel shim for coolant/oil sealing.
That was the only cutting of hay we made from one of our meadows this year and it was a little short in places (thus the shaggy bales).
I was actually heavier in this picture.
These were some hay grazer bales that we bought that were rolled a little green and very heavy. Didn't realize how heavy because someone else loaded, but you could tell it with the truck when rolling out of the field. Then I could really tell when I unloaded because it would lift the back wheels of the tractor if I wasn't careful when backing up.
There aren't any TX chapters out that way. So far TX has us, Houston, San Antonio and Stephenville.
You might want to check with the New Mexico chapter, not sure how far they are from you.
I checked fully expecting to see it on the bump stops, but it was still riding the overloads with some room to travel. Also, where I was parked in that picture isn't the most level ground. I had a pic from an earlier load that made the whole thing look MUCH worse.
Whenever I do that, I make sure the rears are up to max pressure to carry the weight. Although a friend of mine used to run about that same load with his 33x12.50 MTs and only put about 45psi in them. He'd take the load down the highway 150-200 miles and never once had a tire issue (on the truck).
The hay grazer load was full 6' bales because it was a tight fit to get 6 on the bottom with a 35' trailer. Those bales were also rolled up a little on the green side to beat some rain, so they may have weighed in closer to 1700-1800. I just know they were enough to cause the rear wheels on the tractor (which are filled with water) to lift slightly if you came off the clutch too fast when backing up.
As for pin weight, not quite sure. But I'm guessing it's on the heavier side considering the distribution of the load on the trailer. Usually, if I have one or two less than a full load, I'll skip the front bales on the top and keep more weight toward the rear. I much prefer running this load with a dually, but it works with mine.
Originally Posted by RowJ
They sure look like 2,000 pounders!
I'll have to check with a couple of friends from home. There is one guy they haul for that only buys hay by weight, so they have to run all of their loads across the scale in town before heading to his place. Those loads are usually only 5 at a time on a hay wagon, but we can figure bale weight from there.
After 3 years and 5 months, the brushes in my FASS finally bit the dust. It happened fast....running, parked it, then no start. Used my replacement brushes from under the back seat and was back on the road.
I had noticed a little lack of power for a few days, but the pressure was still at about 19 down the road. Now, the power is back and it seems to idle better.
