TXDTR #8 Forum for the Texas chapter #8
TXDTR #8 New Thread for February
Old Feb 10, 2010 | 04:00 PM
AggieJustin's Avatar
Originally Posted by RowJ
Justin, Mine was done back when everyone said you needed braided stainless. Works great but a real pain.
Everything I've read in last few yrs says regular fuel line but some type of sleeve over it at firewall.
Closed, one way system, so closing the needle valve down 98% works well and avoids gauge rattle and pressure leaks.
Where are you mounting it?
RJ
Switching to a 3 pod pillar from the 2 pod I have right now. Going to do some clean-up on my existing wiring that is back there as well. It wasn't my best work when I put them in originally. It's not "all-red" wiring job, but I need a little more slack in some places.
Nylon tubing with compression fittings good enough? With a sleeve where it passes through anything tight.
Old Feb 11, 2010 | 06:32 AM
crobtex's Avatar
I hope you're happy!
Originally Posted by TexasCTD
I just wish that.........IF it is going to stay cold and somewhat miserable...THEN, I'd like to see some good snow!
Otherwise.....im ready for Spring.
Old Feb 11, 2010 | 06:33 AM
Come north, it's not snowing up here...yet.
Old Feb 11, 2010 | 06:34 AM
crobtex's Avatar
I'm pretty sure that's what come in some of the gauge kits.
Old Feb 11, 2010 | 06:51 AM
crobtex's Avatar
Where are you? Radar shows snow all the way to Van Alstyne.
Old Feb 11, 2010 | 06:56 AM
It just started here in Celina a few minutes ago. We were sitting here watching the news of all the snow wondering where ours was.
Old Feb 11, 2010 | 07:35 AM
RowJ's Avatar
Dry and warm up here in Hillbilly country....36*.
RJ
Old Feb 11, 2010 | 07:36 AM
TexasCTD's Avatar
I am!!! It's beautiful!!!! Wish I was off work so I could go get Jared and play in it. I guess I will be "playing" in it all day at work though...
Old Feb 11, 2010 | 07:39 AM
TexasCTD's Avatar
McKinney is covered! How can Celina not have any??
Old Feb 11, 2010 | 07:58 AM
We're covered now. It was a different story at 6:30.
Old Feb 11, 2010 | 08:06 AM
BTW, just a friendly warning for any of you that have done the power window mod where you swap power between the power seat and power window breakers so you have power windows all the time. The little lights on the switches stay on full time when you do that and they draw around 110mA. The normal key-off draw is usually around 7mA
I've always noticed that if the truck sat for a while (a week or two while traveling) that the batteries would be a little slow. I guess that explains it. Not sure if that contributed to the death of one of my Optima Redtops, but I did get a free warranty replacement yesterday at AZ.
Old Feb 11, 2010 | 08:17 AM
crobtex's Avatar
I have had the window mod for 3 or 4 years and have never had the batteries run down because of it. The longest it set was about 7 or 8 days. Lately, two or three days without a problem. I think it depends a lot on how good your batteries are. Speaking of which, have you checked yours lately?
Old Feb 11, 2010 | 08:26 AM
Yeah, checked them out on Tuesday. That is why I got one replaced yesterday. My passenger side battery was pulling down to 4-5V under load. The drivers side was still OK, it would only go down to 10-11 under load. I put a charger on the passenger side and it would take a charge and would hold up under load for about 7-8 seconds, then it would drop like a rock.
Might be more of an issue for me since my truck routinely sits for 3-4 days without being started up. The constant slow discharge, then rapid recharge while running might not be a good for those Redtops. Plus the topper might have been in December when it sat for 10 days in the cold, since it was almost completely dead when I tried to start it (the grids completed drained the batts when I hit the key).
BTW...does your last century truck have the ID lights on the door switches??
Old Feb 11, 2010 | 08:34 AM
crobtex's Avatar
Ha! Ha! Yes.......Ole' Red has the ID lights.
Old Feb 11, 2010 | 09:11 AM
XLR8R's Avatar
I'm replacing the wasted 3G Group 65 batteries in the Cheap Hooker with a pair of Group 31s... that thing has eaten batteries since it was new - and the power window mod only drains them faster.
Didn't get the first flakes up here until 8ish - it's already a winter wonderland outside!
