TXDTR #8 Forum for the Texas chapter #8
NTDTR #8 June 21st at Ardemore
Old Jun 16, 2008 | 12:16 PM
  #121
03RAMBUNCTIOUS's Avatar
I watch wind blow...
Originally Posted by RowJ
Sounds normal +/-. Your 03 probably came with a 190* T-Stat, like my 02?
I switched to a Cummins 180* and love it. Sits at 180-185* all day long....even hauling up to gross weight on a 95* day.
Seems to flow much better than the Dodge modified Cummins 190* T-Stat. Even at Race track...never goes much higher than 200*.
Have you ever back flushed your radiator? Charlie made a tool (and I copied it) that works well. Don't need to remove radiator!
RJ
never done any water works on the truck. just add to the overflow resevoir everyonce and a while.
i was going to do a coolant flush when i bought it, but did not know where to get more pink coolant.
Old Jun 16, 2008 | 01:07 PM
  #122
AggieJustin's Avatar
The device Rowland is referring to is used to flush the dirt from the fins in the radiator. You don't have to replace coolant or anything else, as it cleans the exterior to allow proper airflow.
Old Jun 16, 2008 | 01:18 PM
  #123
yea i was wondering about that, i made that post ^^^ before i saw the pics he had sent...
the tool looks slightly better than my method of laying under the truck, and basically taking a shower with the truck which i have done and it was rather dirty. well it was after doing some back roading in West Texas after a storm, dadgum caliche roads.
Old Jun 16, 2008 | 01:20 PM
  #124
crobtex's Avatar
Here's what that puppy looks like.
Old Jun 16, 2008 | 04:37 PM
  #125
that looks a whole lot more effeceint than my method.
Old Jun 16, 2008 | 05:05 PM
  #126
RowJ's Avatar
Hey, El Prisidente!
Time for the annual "Radiator Backflushing Party" and get together!
Your water....our comsumable beverages?
RJ
Old Jun 16, 2008 | 05:18 PM
  #127
Hey, El Prisidente!
RJ
sounds like a party to me ,
what are the plans for this weekend? still going to OKIE? last i heard the plan changed about 10-15times.
Old Jun 16, 2008 | 06:15 PM
  #128
BBA's Avatar
BBA
I will be at redline if anyone wants to join. If you go you can get $10 off for the dyno at hot street on july 19th??
Old Jun 16, 2008 | 07:08 PM
  #129
so kennedale and caddo mills tracks are 1/8th mile?
thats a bummer, hopefully i misread somethni somewhere.
Old Jun 16, 2008 | 08:02 PM
  #130
BBA's Avatar
BBA
Well caddo mills is 1/8th mile.
Old Jun 17, 2008 | 01:44 AM
  #131
TexasCTD's Avatar
I know Charlie and RJ are talking about something else...(the back flush thingy)....
But you can also drain and refill your radiator every so often too. No need to "flush" if you do this regularly. Just drain all you can from the draincock on the radiator (maybe around 4-4.5 gallons) and replace it with Zerez G-05 and distilled water 1/2 and 1/2. I started adding this procedure to my 20k mileage maintenance interval. It won't get all of the coolant out, but it will get enough out that it's like keeping new stuff in it all the time by doing it regularly. And another tip I picked up from RJ....is to suck out (I use a cheap autozone plastic thingamijiggy) and replace the power steering fluid with fresh ATF +4.
Old Jun 17, 2008 | 05:12 AM
  #132
crobtex's Avatar
Hey, El Prisidente!
RJ
Good idea! I know mine probably needs it. I'll look at the calendar when I get back and see what we can do.
Old Jun 17, 2008 | 07:44 AM
  #133
RowJ's Avatar
I still can't find any racing tires...265x16".
I think Ardmore will be put off a week till the 28th!
Not using ATF of any kind. I'm using Valvoline Synthetic Power Steering Fluid...when I can find it. Non Synthetic Valvoline when I can't.
Don't know on 3rd Gens, but 2nd Gens say not to use ATF due to Hydro Boost assist to the brakes.
RJ
Old Jun 17, 2008 | 09:41 AM
  #134
racergurl06's Avatar
yes, both kennedale and redline are 1/8 mile, i know how you guys want your 1/4 but i think redlines where its gonna be at that night, atleast i hope so! pretty sure were all gonna make it out there even the big red DMAX that ran an 8.28 out at north star on the 31st, should be a good show, hope to see yall there
Old Jun 17, 2008 | 10:32 AM
  #135
bnold's Avatar
I have a brand new michellan 265-16-75 under my truck right now! Now you only need to find three more!
