TXDTR #8 Forum for the Texas chapter #8
February Meet will be in Alvarado, TX
Old Feb 29, 2008 | 09:14 AM
  #466
RowJ's Avatar
Cute!
Not only did he respond late...he never asnwered the question.
I pulled in 4Low...second gear. Was warned that using third, the tranny would down shift towards end of pull and the my CTD would not enjoy that expirience!
Safer this way...but I probably gave up 5' cause max speed in 2nd is 20 mph. (did you get that Brian?)
Old Feb 29, 2008 | 09:19 AM
  #467
XLR8R's Avatar
... not too mention the other 5" you gave up against Brian's MT rubber!
Old Feb 29, 2008 | 09:22 AM
  #468
fordkiller43's Avatar
Originally Posted by bigredBCS
ford killer: are you sure it was mine there was another yellow dodge parked at the end of the arena!
Saw lots of new faces this weekend, nice meeting everyone. I think we need to have an intervention for 03rambunctious! I never saw him without a shiner in his hand! Haha
Eli: yahh!!!!!
Nozzleman, loved the rig!
Its was one of y'all. Not sure what y'all look like so Im not sure. I was parked out in the middle of the parking lot for a while but drove back to the pits and passed by a bad **** yellow cummins. Whoever it was y'all waved to me. I walked around the pits for a little while. Y'all mght have seen me. I was wearing a red farmboys diesel hoodie. I saw quite a few of you under youre hoods so I wasnt gonna come up and bother y'all. I will be at the next meet tho so hopefully I can meet all y'all. The only person I met was Mike (XLR8). It was fun tho guys.
Old Feb 29, 2008 | 10:53 AM
  #469
bnold's Avatar
Most of the pros all claim that a 33" AT is the best overall pulling tire/tread combo...
RJ at least had the AT part right
Old Feb 29, 2008 | 11:00 AM
  #470
bnold's Avatar
Originally Posted by RowJ
Cute!
Using this nifty Calc http://www.42fordgpw.com/tcalc1.html I was running 18.5mph... if I would have used 4th it would have been 27.2MPH! Big difference! 2nd gear 4HI would have been 30mph... Of course this is all granted I could hold the same RPM I held in Alvarado
RJ if you were running at the same RPM I was you would have been running 26MPH, but if you were holding it at 3200 you were running at 23MPH...
Soooo you were running more tire speed than me!
Old Feb 29, 2008 | 11:17 AM
  #471
Diesel-Dan's Avatar
You want tire speed, and want to get the tires spinning off the line.
MT's bite too much....alot of the big guys around here run 33" - 35" BFG/AT that are worn down 50% to give them that slip off the line....
Old Feb 29, 2008 | 11:18 AM
  #472
RowJ's Avatar
After Dyno graph....with HP dropping off after 2800 rpm, I tried to hold it just under 3000 rpm.... whatever speed that was??
Dan - This track was soft, indoor, rodeo sand! Biggest problem was not spinning out on start... or anywhere in first third of pull, IMO.
RJ
Old Feb 29, 2008 | 11:19 AM
  #473
bnold's Avatar
Yep that's what I have been hearing... I just wasn't ready for the 4th gear pull yet!
Old Feb 29, 2008 | 11:21 AM
  #474
bnold's Avatar
RJ
22mph
I held her open from 3600-3800 on the whole run.... Wanted ans much wheel speed as I could get out of that low gear... Figured I was above the Max TQ and HP so if I started bogging down it would hit the max marks!!
Old Feb 29, 2008 | 11:24 AM
  #475
RowJ's Avatar
I can't find gear ratios for 4low? Anybody know it?
RJ
Old Feb 29, 2008 | 11:30 AM
  #476
bnold's Avatar
2.72 ................
Old Feb 29, 2008 | 11:34 AM
  #477
RowJ's Avatar
Thanks!
Brian, I just timed our runs. Close as I can tell we were only 1 sec (max) apart....so average speed must have been very close??
That makes sense with your 3rd at 1.67 and my 2nd at 1.45. You being at higher rpm would have negated most difference. Interesting....NO?
Still don't know best way to pull? Gear? RPM?... etc.
RJ
Old Feb 29, 2008 | 11:37 AM
  #478
bnold's Avatar
your 22mph probably had more slip with your ATs then my 18.5MPH did with the MTs so that sounds about right
Old Feb 29, 2008 | 11:41 AM
  #479
RowJ's Avatar
Yeah... Gotcha! OK, enough analysis until July in Alvarado...... again.
RJ
Old Feb 29, 2008 | 11:46 AM
  #480
bnold's Avatar
Yep til then!!
So any update on Ardmore??
