TXDTR #8 Forum for the Texas chapter #8
February Meet will be in Alvarado, TX
Old Feb 13, 2008 | 11:36 AM
  #256
elirandolph's Avatar
Originally Posted by XLR8R
Forget the dyno, Eli - we need to hook your beast to the sled!
That may be a little harder to talk me into since it is my daily driver. I have to admit it sure is tempting though.
Old Feb 13, 2008 | 12:45 PM
  #257
bigredBCS's Avatar
rowJ Texasctd and bnold are pulling with there dd's! Xlr8r did last year!!
I want to but I'm scared!
Old Feb 13, 2008 | 12:52 PM
  #258
Diesel-Dan's Avatar
My only suggestions from watching sled pulls up here......is to be smooth.....and get the R's up......
If you have a single disk clutch......i would not get to crazy......you will smoke your clutch due to the slipping needed to get the sled going.....I cant count the amt of burned single disk clutches i have seen at the local shop here from pulling.....
If you get to bucking....let off slow and dont HIT THE BRAKES! haha.....
OK...that is my suggestions from what i have seen folks to up here!
ALSO....4Low and 2nd or 3rd Gear.......
Old Feb 13, 2008 | 12:59 PM
  #259
RowJ's Avatar
Originally Posted by bigredBCS
rowJ Texasctd and bnold are pulling with there dd's! Xlr8r did last year!!.
XLR8R was stock clutch and TEXASCTD is a factory 48re. Give it try!
You can always back out of it (slowly like Dan says) if it feels, smells or sounds bad. That's my plan!
Did you get a hitch mounted under your truck?
RJ
  #260
03RAMBUNCTIOUS's Avatar
I watch wind blow...
well i got the FASS installed last night, it was slightly more difficult than i had anticipated, the first time to install something always takes a while for me, i could do it in half the time now... i had a heck of a time priming the pump, then i read the instructions ... OOF. got it fixed right up..
i also could not get the fuel lines all the way seated against the yellow washers, they all fall just short. i even lubed them up.
i cant wait for the alvarado meet, sonuds like alot of good tmies
2wd's cant really pull can they?
Old Feb 13, 2008 | 01:02 PM
  #261
RowJ's Avatar
There is a 2 wheel dirve class in ATPA events (tractors). Don't know about Alvarado??
RJ
Old Feb 13, 2008 | 01:10 PM
  #262
Diesel-Dan's Avatar
They can...if you have TONS of power and HUGE tires on the back........and ALL your weight on the back......so.....
Old Feb 13, 2008 | 01:23 PM
  #263
sounds like its not for me then..
so i need it in this order then, correct???
SLED--my truck--chain/strap--\/insert 4 wheel drive here\/... then would i get the points for being attached to the sled?
hahaha it works in a mud hole when your stuck
Old Feb 13, 2008 | 02:00 PM
  #264
bigredBCS's Avatar
there was 2wd dually pulling at dhra nationals in houston this year...
....he didnt budge the sled
Old Feb 14, 2008 | 12:26 AM
  #265
TexasCTD's Avatar
Mine is still a stock auto...no DD for me. You have a built trans, so what are you scared of???!!!! Get in there SCHOOLBUS!
C'mon....everybody in sync.... "Schoolbus, Schoolbus, Schoolbus"!!!!
Old Feb 14, 2008 | 12:33 AM
  #266
AggieJustin's Avatar
Wrong DD Robert.....he meant "daily driver", not "dual disk". Too many acronyms floating around here IMO.
Old Feb 14, 2008 | 12:43 AM
  #267
TexasCTD's Avatar
Thanks Justin! I goofed that up... Lots of acronyms is right. Yes my truck is my DD. But it does not have a DD clutch...
Old Feb 14, 2008 | 02:44 AM
  #268
bigredBCS's Avatar
I just don't feel like beating the crap out of a truck I'm still making monthly payments on!!!! Lol, I'll just watch you's guys!
Old Feb 14, 2008 | 03:47 AM
  #269
TexasCTD's Avatar
Scott, I really don't blame you. These trucks are very expensive! Maybe you can at least dyno it though....up at Burleson.?
Old Feb 14, 2008 | 06:51 AM
  #270
bigredBCS's Avatar
Oh I'm dynoing for sure..... Hoping to do 500+ and 600 at the dyno in buda in April
