TXDTR #8 Forum for the Texas chapter #8
December GTG at the Shop!
Old Dec 2, 2008 | 03:37 PM
  #31
hotdram's Avatar
Originally Posted by XLR8R
...hope he doesn't wear out Tyler too much - I've got him penciled in to "receive" the G56 when it clears the pressure plate.
Man, you are gonna break that skinny lad's back SNAP
~Rob
Old Dec 2, 2008 | 03:43 PM
  #32
Diesel-Dan's Avatar
Yep - pretty sure that's what Charlie meant... hope he doesn't wear out Tyler too much - I've got him penciled in to "receive" the G56 when it clears the pressure plate.
Evan and I will be there 7ish.
Your are going to have to be specific now…you say G56…you are going to get an earful about how Infinity doesn’t make one and he drives a G37…....
Old Dec 2, 2008 | 03:51 PM
  #33
Diesel-Dan's Avatar
Originally Posted by AggieJustin
Also, what's the preferred material for running the fuel line in the cab to a mechanical fuel gauge? Going to put a needle valve under the hood to control the flow, but wanted something I wouldn't have to worry about leaking/breaking in the cab.
What you said is what I have....and actually RJ as well.....come to think of it...i got my needle valve from RJ IIRC....must have for a VP and unabated fuel pressure going to a mechanical gauge
Old Dec 2, 2008 | 05:33 PM
  #34
crobtex's Avatar
Exactly! At least I'm bringing my angle drill this time.
Originally Posted by hotdram
By "knocking out the HPFP" I assume you mean watching Tyler (RIP) lay on his back installing it while you hold his beer?
~Rob
Old Dec 2, 2008 | 08:00 PM
  #35
AggieJustin's Avatar
Are you just running the nylon tubing from the needle valve up to the gauge, or is there something more durable to withstand the fuel inside it?
Old Dec 2, 2008 | 08:58 PM
  #36
bnold's Avatar
I had a hard nylon type tube that I ran from my needle valve to my gauge for a while... It ended up getting really really soft and I ended up replacing it with a diesel rated 1/4" fuel line with a push loc fitting on the gauge and needle gauge.. Been that way for almost 2 years now
Old Dec 2, 2008 | 10:57 PM
  #37
OK, that's what I was wondering about the nylon tubing. Figured it would be fine for a while, but was worried the diesel would start eating it. I'll have to track down some diesel rated fuel line and add that to my list of projects.
Old Dec 3, 2008 | 06:30 AM
  #38
elirandolph's Avatar
I hope to make this one. I don't have any real pressing things to do to my truck. I can probably help charlie supervise.
I still haven't installed Mikes track bar bushings, maybe he will bring his handy dandy tool.
Old Dec 3, 2008 | 10:22 AM
  #39
XLR8R's Avatar
I'll bring the tool, Eli.
Old Dec 3, 2008 | 10:56 AM
  #40
Diesel-Dan's Avatar
As well mine has been fine for 2 years with the nylon......6 one way have a doz the other.....will work either way IMHO......
Old Dec 3, 2008 | 11:34 AM
  #41
13FOX's Avatar
I will miss the fun....
Old Dec 4, 2008 | 08:29 AM
  #42
RowJ's Avatar
Mine is steel braided. Back in 02, everyone was paranoid about possible diesel leaks in the cab! No fun to work with but will probably out last my truck. Diesel rated fuel line is very stiff...No?
Because the gauge is a closed system, the needle valve can be 99% closed off and still work (actually protects the gauge better that way)...
I'm surprised the nylon tubing would be a problem. Lots of guys using it.
RJ
Old Dec 4, 2008 | 09:03 AM
  #43
Diesel-Dan's Avatar
Happy Birthday Mike!
Old Dec 4, 2008 | 10:36 AM
  #44
XLR8R's Avatar
RJ
Mine is stainless steel braided!
Thanks Dan!
Old Dec 4, 2008 | 11:08 AM
  #45
We expect nothing less!
Happy B-Day Mike!
