twin turbulators and resto.
Old Nov 24, 2011 | 02:04 PM
  #31
stillsmokin209's Avatar
Originally Posted by Stomp
Interesting conversation on setting up the afc and setting up the internal wastegate. I run a pretty tight afc setup and I have my gate to dump at 38psi. When I decide which rout I want to go with a new set up I might just have to try some different things.
Probably going to go with twin ball bearing turbos and then set them up so I can run a bunch of nitrous if I want to. I was definitely not set up to run as much nitrous as I did, and that is why I blew my headgasket. Mine is studded and oringed which is why it probably lasted 9 runs on the dyno before it let loose.
Lucas1 with what you have I am sure you will be over 500hp with water/meth. Nice build.
Stomp
What injectors did you run at the event? Truck looked a bit smokey when idiling, but made good power and sounded great as well. What difference in egt's, boos, and spool up do you see from the hx40 secondary to the 35/40?
Old Nov 24, 2011 | 02:11 PM
  #32
Ahineman's Avatar
Sometimes I can't tell...
are you serious or just pokin' a little fun?
Old Nov 24, 2011 | 03:50 PM
  #33
Stomp's Avatar
Injectors are DDP 100lpm they are a 5x.025 or 5x.026 I can’t remember off the top of my head. They haze pretty bad for DD.
The 35/40 starts spooling 200-250rpms sooner. It makes all the difference in the world when pulling the switchbacks around here with a trailer. It’s the difference between downshifting into 2nd instead of pulling in 3rd. Egt’s are lower down low about 200* or so, but it starts choking up high where the 40 will keep the egts 150* lower when going all out.
Completely serious it makes me want to do some more testing. I am sorry if I came across differently. I am making an effort to be a little more serious now and not letting things get to me anymore. I guess it’s because I am getting older.
I just wish I had access to a dyno. Closest one is 3.5hrs away.
Stomp
Old Nov 24, 2011 | 06:49 PM
  #34
Stomp
Yeah they seemed rather large I will stick to my 35 then, thanks.
Old Nov 24, 2011 | 09:42 PM
  #35
Ahineman's Avatar
Stomp
No problem man, I just wasn't sure.
Sometimes it's hard to tell how people meant for something to come across when you're just reading it on a forum.
Keep up the R&D and we'll see the 1000rwhp mark broke soon.
Old Nov 25, 2011 | 12:31 AM
  #36
Lucas1's Avatar
Stomp
thanks.
now bolt on some ballbearing garrets a ported polished hamilton head and hit the dyno again i think you can get bigger fuel numbers.
jasons truck is cool as hell making that power. but nitrous is cheating
Old Nov 25, 2011 | 12:38 AM
  #37
Lucas1's Avatar
iam terrible with coming off like an ***.....................and i call it how i see it.......bad personality trait
and i would love to get the live topic back just to discuss AFC tunning and AFC mods.
Old Dec 3, 2011 | 10:02 PM
  #38
Lucas1's Avatar
well the body shop is taking a while......at least they are doing a good job.
havent tested the turbo setup yet. but idling an dmoving around the body shop i see a small oil leak at the drain hose to the pan from a crimped hose end....easy to fix.
got a solid three days work on the exhaust intercooler finish and the little stuff after the body shop.
Attached Thumbnails twin turbulators and resto.-106_0003.jpg   twin turbulators and resto.-106_0002.jpg   twin turbulators and resto.-106_0001.jpg
Old Dec 4, 2011 | 05:07 PM
  #39
you gonna do the big line kit in your sending unit while the bed is off?
Old Dec 5, 2011 | 12:23 AM
  #40
Lucas1's Avatar
yeah i was just looking at that in the sticky.
not sure if i will go that route or use a draw straw.
need to drop a dip tube in for the espar as well.
Old Dec 5, 2011 | 08:12 PM
  #41
fatt's Avatar
For what it's worth, the only time my draw straw has ever sucked air was after the low fuel light had been on for about 50 miles and I took off WOT from a stop sign.
Old Dec 24, 2011 | 06:52 PM
  #42
Lucas1's Avatar
some update pics
Attached Thumbnails twin turbulators and resto.-108_0007-custom-.jpg   twin turbulators and resto.-108_0008-custom-.jpg   twin turbulators and resto.-108_0009-custom-.jpg   twin turbulators and resto.-108_0010-custom-.jpg   twin turbulators and resto.-108_0011-custom-.jpg
Old Dec 24, 2011 | 06:55 PM
  #43
Lucas1's Avatar
not sure if the LE badging will go back on or the factory ram 350 emblems.
i have new emblems of of new truck . might put 55oo on the tailgate and just the cummins "c" on the fender
and what do you think about pinstrip?
i was thinking Kawasaki green or maybe a dark gold/copper color
cant decide
Attached Thumbnails twin turbulators and resto.-108_0012-custom-.jpg   twin turbulators and resto.-108_0013-custom-.jpg   twin turbulators and resto.-108_0014-custom-.jpg   twin turbulators and resto.-108_0015-custom-.jpg
Old Dec 24, 2011 | 07:51 PM
  #44
Greed 93's Avatar
Looking good man! What tires you running? Spacers for the duals.?
Old Dec 24, 2011 | 08:50 PM
  #45
BILTIT's Avatar
The liquid filled gauges will most likely lie to you. I have found any gauge under hood needs to have the liquid drained to read correctly.
