Whats the difference in a 2500 and 3500
I was wondering what the difference is in the second gen 2500 and 3500 cummins trucks .Is there a much difference in the earlier ones like 94-95 and the 96-97 ones.thanx
I would think the frames are diff too?
I had a 1500 burban that i installed 3/4 ton axles on and was trying to make truck more heavy duty and in my quest to do this i found the following diff between 1/2 and 3/4
3/4 has
larger brakes
larger brake lines
larger master cylinder,
different proportion valve
heavier springs
slightly thicker frame (on GM it was only by about an 1/18th of an inch) wich over the length of a suburban adds alot of metal.
heavier leaf springs.
Larger axles, hubs,
Just my .02
3/4 has
larger brakes
larger brake lines
heavier springs
Larger axles, hubs,
Just my .02
John
Where do I get a list of EXACTLY what I have in my 2004.5 Cummins 3500 vs. the 2500?
I want to use the mag covers and go to syn oils but am just learning about all of this diesel stuff and have heard many different stories, especially chipping
3/4 has
larger brakes
larger brake lines
heavier springs
Larger axles, hubs,
Just my .02
3/4 has
larger brakes
larger brake lines
heavier springs
Larger axles, hubs,
Just my .02
Put dual wheels and a little larger brakes on the (second gen) 2500 and you have the same as a 3500. The later models even had the same brakes.
There is no frame difference, or spring difference, drive line is the same. Biggest difference is name tags and dual wheels.
It's not a Ford or GM, they are different with the 3/4 being a lighter truck.
