Truck Camper Wiring Fault Code?
Old Jul 29, 2010 | 04:08 AM
Reeder's Avatar
Question Truck Camper Wiring Fault Code?
Hey Guys:
I just bought a 2007 Dodge 2500 Quad Cab 5.9. I'm setting it up for my slide-in Northstar Truck Camper.
I'm installing Happijacs, Air Lift Bags w/ dual controller, and doing the wiring myself. I did all the work on my 2000 Dodge Ram with no problems. An installer at Ketelsen's in Denver told me if I spliced-in to the wiring for the in-bed 7-pin connector (as I did before); the computer could fry or throw a code. He said if I bought his T-harness (for $90) and did the install, it would be fine. I spoke with an installer at Nolan's RV in Westminster who said they simply splice in with "quick-splice" connectors and haven't had any problems. This is how I did the last job and was what I was planning on doing again. But, the guy at Ketelsen's has me wondering about throwing a code, or messing with the truck's computer somehow. The logic makes no sense to me because a connection is a connection, but do you guys have any experience with this?
BTW. I'm only splicing in for tail, L-turn, R-turn, and backup lights. I'm pulling power off an isolator mounted next to the battery so I don't get voltage drop.
Thanks,
Reeder
coffee is cool...
Old Jul 29, 2010 | 06:26 AM
JoshBrown's Avatar
The guy is a liar. I bought one of those harnesses and the idiot sent me one with chevy ends so I spliced it in like you explain and it is fine.
Old Jul 30, 2010 | 01:15 AM
Reeder's Avatar
Thanks for the quick response. I'll be wiring it up this weekend!
Thanks!
Old Jul 30, 2010 | 02:10 AM
Jim Dynomite's Avatar
The t-harness connects to the trailer wiring, so he's right about using it since its safer ( no mistakes).
It's ok to splice into the harness, just make sure you splice into the trailer wires and not the tail-light wires.
Jim
Old Jul 30, 2010 | 03:44 AM
Reeder's Avatar
Makes sense. I'm thinking I might just plug into the 4-way at the bumper (behind the 7-way), run those wires back to where I need them and run a separate power and ground. Should be pretty easy. Thanks.
DuaneWKKC
Jul 26, 2006 12:25 PM
jdcone
Nov 12, 2005 10:53 PM
flathead
Jul 17, 2005 12:03 AM
powerchokeater
Apr 13, 2005 08:36 AM
MB
Oct 22, 2003 08:01 AM
