trailer Tire problems
Old Apr 28, 2004 | 06:09 AM
Dieseldude4x4's Avatar
I had a perfectly good normal looking tire blow this past weekend coming down the mountains in Kentucky with my 3500 on the trailer. That was not a good feeling. That tire totally disintegrated. I think like someone mentioned earlier that it picked up something and leaked down between stops until it blew. I bet we passed 30 cars with flat tires on the trip to Indiana and back. There is so much garbage on the roads now you never know. Saw a guy right in front of us hit a deer and we nearly caught what was left of the poor girl next.
Old Apr 28, 2004 | 08:00 AM
RustyJC's Avatar
Originally posted by Forrest
Know what? Got 33", center to center.
If you have clearance with the chassis, wheel wells, floor of the trailer, etc. at full suspension travel, you might be able to go even larger than the LT225/75! Just give yourself an inch or more clearance between the tire treads - any tire up to 31.5" to maybe a 32" diameter should clear insofar as axle spacing is concerned.
HERE'S Michelin's webpage for the XPS Rib - click on the Sizes and Specs tab for more information on tire diameters, load ratings, etc.
Rusty
Old Apr 29, 2004 | 08:56 PM
Srigs's Avatar
Always balance the trailer tires and check the alignment. Most trailer dealers do not balance the tires which causes lots of problems. Check the front to back distance from axle to front of the trailer they should be the same. If either of these are off then you will have problems.
Always use max air pressure... Srigs
DJ Turbo.
Oct 13, 2011 09:11 PM
JIROBBI
Jul 24, 2007 09:51 PM
cujo
Jul 13, 2006 08:14 AM
gnarlykaw
Aug 22, 2004 07:52 PM
Amish hauler
Apr 8, 2004 07:07 PM
