Trailer brake repair
The trailer is a '94 Kit over 24' long. The brakes are not working properly and the linings look about worn out.
How do I determine who manufactured the brakes so I can get parts? Or, should I just replace the whole thing backing plate and all?
Thanks
Thanks
Re:Trailer brake repair
The brakes on trailers and pretty standard. On that trailer you probably have 2X10 brakes , axles made by dexter. Just take them to a auto parts store, they should be able to match them up. Check the bearings and replace if needed.
Thanks clifford, I guess I'll soon find out if they have return springs and grease seals. I noticed that the electrical connections aren't water tight and poorly done. Nothing like another project! :
Chris
Chris
There is a place called Agri Supply here in Virginia that sels the whole backing plate brake assembly for just a little more than the shoes cost.
There is a site, www.redneck-trailer.com that sells everything for trailers that I deal with also.
DD4X4
DD4X4
Just go to your local RV dealer, anyone worth a penny will carry the whole assembly for about $40 - $60 dollars. Then all you have to do is unbolt the old ones and bolt in the new ones and hook up the wires.
I've noticed in the Camping World catalog the whole works for $53 - $64 each. What do shoes typically cost? What are the odds I'll need oversize shoes after turning the drums?
The brakes should cost about $20.00 a aset so it would be $80.00 they don't make over size brakes if turned to much you replace the drums, should be stamped max Dia. on the drum.
I'd read in a RV repair book that if you increase dia. by .045 your s'posed to get .030 oversized shoes. Just wondered if there was anything to it. Guess I'll start by pulling all the drums and take them in to see what I got.
Thanks, Chris
Thanks, Chris
Jim5870
Oct 28, 2014 03:08 PM
Amish hauler
Apr 8, 2004 07:07 PM
