Towing weight
Old Mar 22, 2004 | 11:47 PM
nubby3's Avatar
Towing weight
How much weight are people towing with 2500.I'm towing 30' FK Cardinal T/T.Weight 6990,tongue weight 920.Trying to find out if I'm O.K. Reciever hitch rating is 10,000 lbs & tongue weight rating is 800 lbs.I use a weight distribution
98.5 auto,3.55 rear,edge ez,k&n,4"magnaflow turbo back.
Old Mar 23, 2004 | 12:51 AM
ten8fiftyone's Avatar
You're fine, by a long shot!!!.....Just make sure you have a tranny cooler
Old Mar 23, 2004 | 06:18 AM
John H's Avatar
Re: Towing weight
Originally posted by nubby3
How much weight are people towing with 2500.I'm towing 30' FK Cardinal T/T.Weight 6990,tongue weight 920.Trying to find out if I'm O.K. Reciever hitch rating is 10,000 lbs & tongue weight rating is 800 lbs.I use a weight distribution.
Have you actually weighed it ready to go? Or is that what Cardinal say it weighs.
I used to have a 30FK Dutchman that was supposed to weigh 6500 lb with 830 lb tongue weight. By the time I was ready to hit the road, it weighed in at over 7500 lb, and 1100 lb. tongue weight. That front kitchen with all the pots, pans and food, plus the gas bottles and battery is a killer. My 93 truck was rated 900 lb. max for tongue weight, so I was over by a good 200 lb. I suspect you may be too. However, it did tow very well for over 20,000 miles.
John
Old Mar 23, 2004 | 11:34 AM
nubby3's Avatar
That is trailer specs from Forest River.So I'm actually heavier.
Old Mar 23, 2004 | 01:12 PM
Haulin_in_Dixie's Avatar
I am not speaking for the receiver hitch, but the truck will pull twice that, easily.
Old Mar 23, 2004 | 01:27 PM
RustyJC's Avatar
With a 2500, you're a lot better off with a TT than you would be a 5th wheel. The higher pin weight of a 5th wheel as compared to a TT quickly puts a 2500 over its 8800 lb GVWR.
So, are you over your GVWR? Only the scales will tell for sure.
Rusty
Old Mar 23, 2004 | 08:55 PM
blackjack's Avatar
It sounds like you are good to go. If you think you need more hitch security go with the putman class V hitch it has a 15,000 lb rating and I saw them on e-bay for 125.00 I have a 29' forest river and tow with no problems or concerns just give it the respect it deserves.
John Marshe
Aug 14, 2020 09:00 PM
Purplezr2
Jul 25, 2011 04:31 PM
j28s
May 25, 2003 11:13 PM
j28s
Feb 24, 2003 05:44 PM
rkelso98
Jan 12, 2003 01:20 PM
