Towing with a 93 Auto 2wd
Old Aug 9, 2013 | 10:27 PM
mdgardner's Avatar
Hey Guys
I have a little farmall super c (weighs around 3500lbs) I plan to take to a few shows. I have a little 20+5 gooseneck deck over trailer that weighs around 4k max empty. Had it built light to pull with a 2011 1/2 ton Chevrolet and it did fine. My question is, would you guys go 100 miles from home with my setup with that a518 trans? Will have a few hills to climb? Trans seems to shift fine. Just wondering. I dont have the $$$$ right now for a build or a converter, besides, I really want a 5 speed.
Old Aug 10, 2013 | 07:15 PM
j_martin's Avatar
Shouldn't be any problem at all. The A 518 being a non locking transmission picks up a bit of cool and fuel mileage with a low stall converter. Stock guts can take stock HP all day. If you're going to turn up the engine, it would be worthwhile to build it up a bit.
I pulled an 8000 lb fiver which would have about 4 times the wind resistance of your rig across the prairie in 95 degree heat at 65 - 70 with a bone stock transmission. It did have the factory fan cooled frame mounted cooler.
Old Aug 10, 2013 | 08:51 PM
mdgardner's Avatar
Thanks.
I don't believe I have any extra coolers on my truck. It has never towed heavy. It was a highway truck all its life. I just installed a gooseneck hitch, and brake controller. Only mods done are muffler cut off, Fuel screw turned 3/4 turn. Star wheel turned 1/2 turn, and the fuel pin turned. It doesnt smoke at all when I get in it so I'm assuming the egt's will be OK? Also should I run with OD off the entire time I'm towing? Sorry for all the questions. Im just paranoid. I'm trying to take care of my ol truck, Its all I got.
Thanks
Drew
Old Aug 11, 2013 | 01:04 PM
j_martin's Avatar
Originally Posted by mdgardner
Thanks.
Thanks
Drew
Unless you plan to pull long hills, as in Rocky Mountains in hot weather, you should be fine.
Old Aug 12, 2013 | 08:42 PM
mdgardner's Avatar
Thanks
I just get paranoid reading what people say about the transmission. Some folks make out like you cant use them for anything but driving, and you better baby it then. Anyway, I guess if you drive it sensible it should be ok. I don't cowboy around, so im hoping I will be ok. Im going to try to have the bands adjusted soon.
Thanks for the advice!!!!!
Drew
90 power ram
May 23, 2011 02:44 PM
Jordan5687
Feb 18, 2009 02:48 PM
Bobcat698
Apr 1, 2007 10:26 PM
Superduty
21
Jun 17, 2005 11:31 PM
WalkingHorse77
Jun 25, 2003 12:52 PM
