Towing a 28' Cargo trailer?'s
Old Apr 26, 2006 | 07:24 AM
Tyler_02's Avatar
My dad just bought a 28' Enclosed cargo trailer and is gonna be using my truck in my sig. its a V-nose i believe but he should be able to pull it in OD? Its about a 180 miles long trip and its flat. And what about the wind if its blowing hard...would it be better to use the Tow/Haul Feature? Thanks guys i think the trailer weighs somewhere around 4500lbs
Old Apr 26, 2006 | 08:06 AM
bulabula's Avatar
The only thing I'd be worried about is him getting a speeding ticket with your truck....
Old Apr 26, 2006 | 08:30 AM
Tyler_02's Avatar
BulaBula:
The reason i ask is this is my first diesel i had a Ford F-150 with a 5.0 and it could barly pull my 1600 lb trailer. Now when i pull it with my truck in the sig i have to worry about ripping the frame apart.
Old Apr 26, 2006 | 08:58 AM
Bart Timothy's Avatar
I still remeber the thoughts I had the first time I ever towed with my '01, back when it was brand new. It felt kind of like a slug .. until I came to the first good hill. Pulled right away form a Caravan and Ford Explorer which were traveling along with us.
Old Apr 26, 2006 | 09:07 AM
RonP's Avatar
There are alot of opinions on this but I have a fully decked out edge race trailer and with it loaded and my race car in it(about 8500lbs), I always tow in OD on flat roads and even some slight grades. If I can maintain 55mph without lugging, I stay in OD. I have almost 50,000 on it so far and seems to be fine.
Old Apr 26, 2006 | 10:46 AM
bluedodge3500's Avatar
I have a 24 enclosed trailer loaded with all the race car and equiptment it is about 7200 lbs I run with the cruise on in overdrive and edge on 2x5 stock tranny and 90000 miles so far so good (knock on wood) steep hills it down shifts and I just watch the pyro gauge and then back to overdrive and cruise
Old Apr 26, 2006 | 10:51 AM
Patrick Campbell's Avatar
Tow/haul on the new trucks does not lock out OD it just changes the shift patterns. I would just use tow/haul mode and see how it goes.
Old Apr 26, 2006 | 12:20 PM
RonP's Avatar
Sorry, but that is not correct. On my 04 Tow haul locks out OD and doesn't appear to do anything to the shift points. It seems like they have made a couple changes to that function on these trucks in the last few years.
Old Apr 26, 2006 | 12:24 PM
Tyler_02's Avatar
RonP:
On mine on the shifter i press it once for Tow/Haul and press it again and it locks OD out.
Old Apr 26, 2006 | 12:47 PM
RonP's Avatar
Originally Posted by Tyler_02
RonP:
Yep, I knew that. I know there are a couple different ways but on the 04's its basically OD on/off. Shouldn't be called tow/haul.
good luck
starting in 05 tow/haul does not lock out OD. It does in 04 and prior. I have never driven an 06 so I don't know, he says you have 2 options then I believe it, which I think is great (the inability to lock out OD was a pain). I would suggest using tow-haul mode and see how that goes, since you will be towing.
truckjunkie
Jan 27, 2006 07:35 PM
2500CTD
Oct 2, 2005 09:18 PM
dssimecek
May 27, 2005 07:51 AM
moparguy
Mar 29, 2005 09:35 AM
Hoss
Nov 29, 2003 06:09 AM
