Tire Question Brand & dependability question
Old Dec 13, 2005 | 10:53 AM
supr's Avatar
Exclamation
ST and LT tires ARE DIFFERRENT. The manufaturers will tell you so. ST are, in theory, designed for trailers that experience serious, belt breaking jackknifing. LT tires are designed to be on a truck, SUV, with thinner side walls for a better ride. GoodYear had an LT all steel tire that were put on heavy 5vers. These has a history of coming apart, sometimes with serious danage. Thus, they came out with the rST, for heavy 5ers. Completely diffrrent design.
So, just remember, when your LT tire comes apart on a heavy 5er(Or not so heavy?), you heard it hear first, not from the old wife.
Goodyear had a line of ST tires that are OEM on a number of reputable makers.
They will stand behind their tires if things go wrong. They are after he RV business and treat their customers well, especially if you go to corporate.
Old Dec 13, 2005 | 11:03 AM
RustyJC's Avatar
The G-rated Goodyear Unisteel G614 RST is DOT-labeled LT235/85R-16. I know. I have them on my 5th wheel. I've looked for myself.
Rusty
Old Dec 13, 2005 | 11:39 AM
Snoking's Avatar
Goodyear ST Speed Ratings
http://www.goodyear.com/rv/pdf/rv_inflation.pdf
All of Goodyears ST only have a 65 MPH speed reading.
And they only go to 65 lbs of air and 3000 weight, that is why you see LT going on the larger 5th wheels. The Michelin XPS Rib is still the best trailer tire up to its rating. Then you have to jump the GY G rated LTs.
SNOKING
Old Dec 13, 2005 | 01:48 PM
induchman's Avatar
trailer tires
Originally Posted by RustyJC
Are these 5th wheel trailer tires or tires you had on your truck? This discussion is addressing 5th wheel trailer tires. The Wrangler is a fabric-and-steel construction radial, and the Wrangler HT is normally used for 5th wheel applications. This E-rated tire is what people are changing out to the all-steel E-rated Michelin XPS Rib. The G-rated all-steel Goodyear Unisteel G614 RST isn't even remotely related to the Wrangler series of tires.
Rusty
ST (trailer tires) don't hold up at all. They don't support enough weight. They're just ok for light travel trailers and 5er's. But let's get serious here-LT's are needed instead. My horse trailers have triple 7000# axles with E rated tires on them.
The MTR's were advertised as a replacement for the Workhorse series, as being better built to handle rough roads. We put them on the trailer instead of the truck, just to see if they would last - they didn't. The only reason, I'd go with the XPS is because they can be re-capped.
prlsnpsdodge
May 31, 2013 11:26 PM
L-ofalab
Mar 18, 2013 03:16 PM
BigfootTrucking
Mar 23, 2012 07:50 AM
jlipskoc
Oct 6, 2009 05:29 AM
89f150
Sep 13, 2008 05:23 PM
