Sidewinder Airborne - what are the 2 bolts UNDER the airbag
Old Sep 25, 2015 | 12:34 PM
Bubbaboy's Avatar
There are 2 3/8" bolts hanging down inside the cavity of the SAirborne (lots of thread showing with flat washer), just about directly below the aire bag. As you can see in behind the shock absorber. Are these to stay there are they look, are they to be tightened, removed or ?.
Thank you...
Old Sep 25, 2015 | 01:36 PM
BILTIT's Avatar
Do the bolts thread into the airbag to hold it down? Hard to tell without a defferent picture.
Old Sep 25, 2015 | 01:39 PM
Bubbaboy's Avatar
Sidewinder airborne Bolts
Sorry, there is no way to tell as they go in to the bottom of the steel surrounding the are where inside the airbag would be.
Old Sep 25, 2015 | 01:43 PM
BILTIT's Avatar
I am 90% sure those are the bolts that thread into the bottom mount plate of the airbag.
Reese 5AS16K 5TH AIRBORNE SIDEWINDER Manual
Old Sep 25, 2015 | 01:44 PM
Bubbaboy's Avatar
Could very wellbe. They are pretty long so not sure they would even be able to be screwed in...maybe they just bottom out as they are...strange...
Old Sep 25, 2015 | 01:46 PM
Bubbaboy's Avatar
Right I think they are #8 & 13 in the instructions...
BILTIT's Avatar
Tighten them up, they go through a thick plate of steel so they would need to be a decent length. Hopefully they are still threaded into the bag mounting plate or else the whole thing will have to come apart to remount it.
Old Sep 25, 2015 | 01:49 PM
Bubbaboy's Avatar
Thanks for the input I will see what happens...it is so heavy I need to have the shop take it apart with thier forklift every time we work on it...
LFD2037
Feb 26, 2008 05:24 PM
truckjunkie
Jun 3, 2005 09:28 PM
Jerry R
Dec 21, 2003 04:20 PM
John_P
Jul 29, 2003 09:18 PM
Rich Shahoian
22
Oct 28, 2002 01:40 PM
