RV refrigerator problem
Old Aug 25, 2008 | 08:43 PM
TJE's Avatar
TJE
I need some help. I've had my frig. stored since Jan. of this yr. The freezer is working, but the frig. part is not. Any body ever experience this, or have any ideas?
Thanks, Tony
Old Aug 25, 2008 | 10:17 PM
TonyB's Avatar
Try posting over at rv.net They have a LOT more experience with RV stuff.
Tony
Old Aug 26, 2008 | 12:02 AM
Xonid's Avatar
is it a Dometic? there's a recall on their frig. Here's the link.
http://www.dometic.com/enus/Americas...ll-Information
Good luck with it.
Edit - Opps - just realized there was a sticky on it.. sorry about that..
Old Aug 26, 2008 | 08:48 AM
hubmonkey's Avatar
Thanks, Tony
If the freezer is getting cold then the refridge should work. Have you looked at the fins in the fridge? There is a thermo wire that attaches to the fins, at least on Norcolds.
Another thing to try is to take a small fan and pull the side cover off your RV and have it blow up the flue. Make sure there are no obstructions in there like dirt bauber nests.
Is it cooling on electric or gas?
Hub
Old Aug 26, 2008 | 10:24 AM
CamperAndy's Avatar
As Hubmonkey said, if the freezer is working then the fridge is also working. Be patient and it is best to add a few bottles of frozen water to accelerate the cool down. Use a thermometer and not a guess that the air temperature is not getting cold. A normally operating RV fridge works between 35 and 38 degrees.
Old Aug 26, 2008 | 07:35 PM
TJE's Avatar
TJE
Hey guys thanks for the help. Yes all is working frig. and freezer I just can't hear the thing hum or anything so I thought it was dead. It is affected by the recall...I've got to take it in next week.
Thanks again, Tony
Old Aug 27, 2008 | 11:24 AM
01RAMer's Avatar
There won't be any hum as there is no compressor. The re-call is a safety issue if a line cracks, to avoid a fire. ReCall has been expanded to newer frigs. Doesn't sound like you have this problem yet.
Weg
Oct 21, 2012 01:57 PM
AlCorr
Sep 2, 2009 10:53 AM
Equalizer 2
Aug 7, 2008 11:44 PM
dodgeguy71
Sep 24, 2007 08:26 PM
wade234
Apr 27, 2007 09:47 PM
