rv question
Old Jan 24, 2008 | 06:39 PM
06 ky diesel's Avatar
rv question
my father has an allegro bus with a freightliner chassis and cummins, 2000 model. he is planning on buying a comp box from edge i think. he needs a pyro but the rv is a diesel pusher (rear mounted engine).
anyone know if i can get a pyro with an extra long set of wires to run all the way to the front of a 36-40ft. rv
also, anyone know of any other boxes. i was told it is a b-series cummins with 275hp.
Old Jan 25, 2008 | 07:27 PM
Skip H's Avatar
http://www.o-f-i.com
89-2005 5.9L Dodge Cummins , ISSPRO Pyrometer Gauge Kit , (colored face) , measures exhaust gas temperature , (R3607VWR gauge , 8 ft lead wire , 1/8 in. NPT screw-in thermocouple) R3607VWR-6K $138.42
LEADWIRE 35 FT R660-35 $45.58 LEADWIRE 45 FT R660-45 $57.87
HTH This is where I got mine.
Old Jan 25, 2008 | 08:11 PM
PChouinard's Avatar
If you match the type, material and size of the wire, I think you would be able to splice your own extension from the guage to the probe. The thermocouple wires to the outboard engines on our aircraft run an extensive distance between guage and coupler (down fuselage, around wing root, down wing and then down the pylon to the turbine section. Could be 50-70 feet of wire there..
mkeanglorldo56
Nov 4, 2007 12:34 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
