Roof Mount A/C units
Old Jul 10, 2007 | 10:26 PM
srt20's Avatar
Hi again guys! I have a new question for you all.
In case you havent read my other post, I bought a 28' enclosed car hauler. I plan on using it to haul my race car and also to haul my ATVs and be my "redneck camper". So I need to put a air conditioning unit on it. It will be all open inside no walls or partitions.
So any suggestions on a roof mounted a/c unit? Maybe a ballpark figure for price and installation? Thaks again guys, Bret
Old Jul 11, 2007 | 07:45 AM
hamilton71801's Avatar
A few years ago I had to replace my 13K unit on my camper. The cheapest price I could find (Carrier V) was PPL in Houston which was @$650 shipped to my door. I already had the hole in the roof so it was simple to swap them out. I would think that it wouldn't be too much of a big deal cutting the hole, just the initial blade to the roof would make me second guess myself. Just measure 2,3,10 times and cut once.
Old Jul 11, 2007 | 11:40 AM
Bonshawman's Avatar
Check out Camping World on line. Price w/install should be under $1,000. Do you have a ceiling w/insulation ? Wiring route ? How are you going to power it ??
Old Jul 11, 2007 | 03:00 PM
srt20's Avatar
The ceiling has plywood or whatever it is on it. There is conduit running down the ceiling to feed the lights that are ceiling mounted. So I figured I would have the wires for the A/C in the conduit. I dont plan on installing it myself. I dont wanna leaker....lol. Just wondering what brands seem to be the best and what BTU I might need. Thanks Bret
Old Jul 11, 2007 | 03:09 PM
The conduit will have small gauge wire (12V) for the lights so you will have to put some house wire in there. I wouldn't get any smaller than a 15K since it's not insulated, heck my 13.5K can barley cool my TT.
Old Jul 11, 2007 | 03:26 PM
srt20's Avatar
Oh yeah, I guess I meant to say I would run some new wires through the conduit just for the A/C unit. Bret
Old Jul 11, 2007 | 04:13 PM
tony597fitter's Avatar
If you dont want to install yourself, just go to a local RV dealer and they will set you up.
Old Jul 12, 2007 | 02:36 PM
supr's Avatar
The 15k run about $700. Either Coleman or DuoTherm/Dometic are very reputable. The 15k draws about 15amps, maybe more at start up. I guess you have 12V circuits?
A professional installation is a good idea.
Old Jul 12, 2007 | 03:26 PM
srt20's Avatar
Trailer has a breaker box for 120v, and seperate 12v system for 2 smaller cargo type lights. A/C would be run off of 120 plug at campground or my generator when electricity is not availible. Yes it will be professional installed. Its a nice trailer and I dont wanna turn it into a junk box. Bret
Old Jul 12, 2007 | 03:34 PM
supr's Avatar
One other thought, these weigh 200-250lbs, I think. I trust the roof is built for this?
Old Jul 12, 2007 | 03:38 PM
srt20's Avatar
Im almost sure it will be fine, but I will check before buying anything. I see a good number of trailers like mine with units on top.
Old Jul 12, 2007 | 08:03 PM
CoastalDav's Avatar
If you think you'll need a little heat in that Red Neck RV, Carrier also makes a air conditioner with a heat pump for about 100 bucks more. Same size as the other ones. Works great down to 40 degrees. After that you gotta get a fire going somewhere.
http://www.pplmotorhomes.com/parts/r...-heat-pump.htm
Dave
Old Jul 13, 2007 | 07:43 AM
johnh's Avatar
also, make sure your generator is big enough, a generator that is almost big enough will ruin an AC unit
Roperteacher
Nov 16, 2007 10:13 AM
Racing41
Aug 31, 2007 11:53 PM
firestorm
Feb 26, 2006 07:59 PM
GSW
Jan 20, 2006 09:42 PM
BearKiller
Dec 12, 2005 08:03 AM
