Reverse Gear to High
Old Apr 22, 2004 | 10:06 AM
DAYTRIPPER63's Avatar
Gear vendors makes an over/under unit
Old Apr 22, 2004 | 08:55 PM
db's Avatar
db
Nope -- GVs are only overdrive units. Nothing offered that lower the 1st gear. It's only a "underdrive" for 2,3,4,5 and 6th gears.
db
Old Apr 22, 2004 | 10:07 PM
Begle1's Avatar
If you need an over/under-drive unit, I've heard good things about US Gear. I've never dealt with them, and they only offer either over- or under- drive splitters, but if their website is to be believed they are built tough, light and not too highly priced.
There website is as follows: www.USGEAR.com
Oh, nevermind. I see you've already heard of them. My bad...
Old Apr 23, 2004 | 03:37 AM
Ramflasher's Avatar
I have also heard good things about the US Gear unit. A friend of mine got the gear vendor, and wishes he would have purchased the us gear.
Old Apr 23, 2004 | 08:51 AM
Mopar_Mudder's Avatar
If you are buring the clutch I have to assume that you are also giving it fuel and bringing the RPM's up. Leave the gas pedal alone and let the engine do its work, it will apply more fuel to keep from stalling. I think by changing your backing style you should have nothing to worry about.
I back up a 22,000# trailer into spots all the time with no problem at all. Heck I have wished I had a higher geared reverse some times.
Old Apr 23, 2004 | 10:55 AM
Hoss's Avatar
Thats MR Hoss to you buddy!
Re: Reverse Gear to High
Originally posted by spaman
I have a 2003 Dodge 1 ton 2wd Dodge Cummins Diesel w/ 6 spd manual tranny, 3.73 gear ratio. I pull a 15000 lbs gooseneck trailer when loaded. When I back up in a tight area, I have to creep, so I have to ride the clutch, & smelled the clutch burn. Anybody have any suggestions on this matter. And also I was told about the U.S. Gear Dual Range UnderDrive Aux Transmission Option, But just don't know.
Thanks,
You do realize that you are overweight pulling a 15,000 lb gooseneck, right? I'm not going to play weight police, but I thought you should be aware because many here will likely criticize you for it.
Old May 11, 2004 | 01:56 AM
Barry Smith's Avatar
"You do realize you are overweight pulling a 15000lb GN?"
You are only overweight if you can't stop it!
Old May 11, 2004 | 11:07 AM
Haulin_in_Dixie's Avatar
If everything is right the brakes on the truck should stop the GVW of the truck, the brakes on the trailer should stop the GVW of the trailer, that equals proper brakes for stopping.
Old May 11, 2004 | 11:19 AM
bulabula's Avatar
Re: Re: Reverse Gear to High
Originally posted by Hoss
You do realize that you are overweight pulling a 15,000 lb gooseneck, right? I'm not going to play weight police, but ..
I think they just did?
Old May 11, 2004 | 11:27 AM
FiverBob's Avatar
Sic'em, Hoss.
Old May 11, 2004 | 11:29 AM
FiverBob's Avatar
Spaman,
I am backing up 16000#, up hills, tight maneuvers - - never had a problem. As stated, don't touch the go pedal - - let the governor keep the rpms low, but sufficient. Work at letting the clutch out all the way as much as possible.
spaman
May 30, 2009 06:52 PM
hobbz
Aug 30, 2008 03:47 PM
DodgeDemon
Aug 17, 2007 11:25 AM
Hummin Cummins
Jun 5, 2003 11:27 PM
mymaur
17
Apr 22, 2003 05:40 PM
