Rental Towing #'s
Old Jan 16, 2007 | 10:58 PM
jj3500's Avatar
Rental Towing #'s
Just curious...how heavy is this set up. 16' box truck rental, Ford Econoline 350, loaded with 1 bedroom apartment contents and a rental car carrier with a 3800lb. car. The front of the truck is tipped up slightly and the front tires are slightly of camber now. Rides fine with all this going on.
Thanks for information.
Old Jan 17, 2007 | 12:26 AM
CrazyCooter's Avatar
Sure it is over recomended GCVW. Who cares?
Drive it like a rented car.....After you unload the goods.
Old Jan 17, 2007 | 10:22 AM
XLR8R's Avatar
Originally Posted by jj3500
Ford Econoline 350 Rides fine with all this going on.
It does?
What tow truck were you hooked to?
Old Jan 18, 2007 | 12:14 PM
dssimecek's Avatar
If you are going to be driving at night, check the headlight aim. Might not ever hit the pavement with the front end up. Make sure you have the correct tool to adjust the headlamps.
be safe out there
Old Jan 19, 2007 | 01:09 AM
jj3500's Avatar
Headlight aim is not bad at all. Its shooting too far off but now horrible. The tow truck, its a ford econoline 350 gas motor with a 16' box. Your typical rental vehicle. Oh, its a dually. I did the MPG by hand, low tens.
Old Jan 19, 2007 | 11:26 AM
jrsmokestacks's Avatar
-16' chevy 3500 box truck(loaded with tools, compressor, ect.)350gas/oil burner
-20' equiptment trailer
-slightly modifed tj
Total weight: 21,xxx
Last time I pulled this set-up, averaged 6.4mpg's. Milage gets worse and worse. Gotta fix the overfueling problem, the pipes between the manifolsds and cats are purple and the tail pipe looks like a diesels.
kingofdodge7131
Jun 17, 2005 01:51 PM
fourwhls00
Dec 31, 2004 07:13 AM
PADZZ
Jun 12, 2003 07:36 PM
Jack Thorpe
Apr 7, 2003 01:01 AM
