Question On Trailer Tires
Hey guys.
Im looking at a flatbed utility trailer the previous owner used to haul around a backhoe.
Pretty stout trailer and a decent price.
However, it needs tires and the current axle configuration requires a tire size of 7x14.5 (mobile home size tires).
The axles have a brake/hub assembly that is much like that of older mobile homes where the wheel is an outer rim that employees 5 lugs with tabs to hold the rim in place.
I understand that these tires are not easy to come by and are expensive when found.
How easy would it be to change the hub assembly to use a more conventional wheel/tire combo?
Rich.
Rich.
Hey guys.
Rich.
Rich.
JIM
I just went through this whole ordeal. This is where I got my tireshttp://www.trailertiresandwheels.net...278/page/45029 I bought Item #B1406. I needed the 3000lb rating. These are Tow Master by Greenball.
You can get the drums here http://shop.easternmarine.com/ I only ordred the brake assemblies from them but they have what you need if you want to change out the drums. They had the best price I could find on genuine Dexter brake assemblies.
05-29-2009 10:24 PM
sakisaki400
23
12-31-2006 10:17 PM
