Is this pushing it
Old Jan 30, 2009 | 09:38 PM
YZ3500F's Avatar
Is this pushing it
I have a 2002 3/4 ton with a 6 speed and plan on pulling a 28 foot trailor from minnesota to oregon. The catch is that the trailor will probely weigh in at around 15000 pounds. Would this be pushing the truck too much and not be recomended and if you have any tips im all ears
Old Jan 30, 2009 | 09:44 PM
rebal's Avatar
you will be fine my 5er tips in at 17000# and it pulls it fine even before the mods
Robert
Old Jan 30, 2009 | 09:45 PM
YZ3500F's Avatar
well see thats the problem its not a 5th wheel
Old Jan 30, 2009 | 10:11 PM
rob24vctd's Avatar
Unless you got a bigger turbo its gonna be hot with 150hp injectors and your taller tires, towing that much. As you get closer to the northwest here there is some pretty good sized hill climbs and passes. and also thats alot for a bumper pull. Is the trailer even suitable for that kinda wieght?
Old Jan 30, 2009 | 10:19 PM
67HotRod's Avatar
I'm guess your using WD (Weight dist) bars on that trailer? Assuming its a bumper pull.
Old Jan 30, 2009 | 11:27 PM
rebal's Avatar
put class 5 receiver and a w/d hitch and go for it, a lot of 3 axle toy haulers are that heavy (bumper pulls) you might need a CDL with that wieght
Old Jan 31, 2009 | 12:41 PM
YZ3500F's Avatar
ya we have a w/d hitch thats the only thing im worried about is the rockies and not so much going up but coming down
Old Jan 31, 2009 | 12:54 PM
YZ3500F's Avatar
oh and the 15000 is the combined load of trailor and the actuall load cause i figure a traillor that size would have to weigh in at around 5000 pounds just sitten empty
Old Jan 31, 2009 | 01:15 PM
annabelle's Avatar
I use to pull that up Wolf Creek pass with a GMC 2500 which had a built 350 cubic inch engine.....wt. dist. hitch....no problem.
Old Jan 31, 2009 | 01:16 PM
rebal's Avatar
well heck if its 15k total and you have a 6spd truck you wont know its back there
Old Jan 31, 2009 | 05:07 PM
jiMMyCTD's Avatar
let er rip, just b in right gear on the wy down. i wouldnt hezitate going anywhere right now with ours.
http://www.toyhaulermagazine.com/for...pe=post&id=264
Old Jan 31, 2009 | 08:46 PM
Jeff in TD's Avatar
Do you have a Jake or some other exhaust brake?
Old Jan 31, 2009 | 09:58 PM
hamilton71801's Avatar
I'd run with the edge off to keep temps down. I turn my XZT+ off when towing and have never had any problems with hotness. Also keep those RPMs above 1800.
Old Feb 2, 2009 | 07:45 PM
YZ3500F's Avatar
nope no jake brake just trailor brakes
Old Feb 2, 2009 | 08:46 PM
jiMMyCTD's Avatar
fixed pic.
just gear down for the downhills.
