Pullrite Superglide clucking noise....
Old Sep 30, 2003 | 10:06 AM
03CTDCO's Avatar
After pulling around our new 5er I noticed loud cluck when
stopping and then another loud cluck when pulling away from
a light...sounds like some play or slack in the kingpin and the locking horse shoe. Any ideas?
Old Sep 30, 2003 | 12:20 PM
SuperGewl's Avatar
Re:Pullrite Superglide clucking noise....
Check to see if there is any play between the lower Turntable Cam Arm and the Nylon Block. If there is then you need to remove the play. ;D
Old Sep 30, 2003 | 12:44 PM
03CTDCO's Avatar
how do you remove the play?
Turn that big middle adjustment bolt?
Old Oct 1, 2003 | 02:44 PM
t6_man's Avatar
Yes, you need to adjust the big bolt which has the lock nut. Loosen the lock nut, then tighten the bolt finger tight. Then tighten 1/2 turn more and retighten the lock nut.
DanTana
Oct 24, 2005 03:56 PM
03CTDCO
19
Mar 9, 2004 07:10 PM
03CTDCO
Oct 5, 2003 09:22 AM
03CTDCO
Sep 27, 2003 01:46 PM
Nov 27, 2002 12:47 AM
