Production date tire codes
Old Sep 13, 2004 | 01:49 PM
DSjockey's Avatar
Hi,
My 5er has Dean tire and rubber Trailcat LT LT235/85R16 load range E tires on it, the 5er is a 2001 model but I wonder if the tires are older than that as I've heard of manufacturers buying large quanities and then they sit around for quite a while untill they get used (these tires appear to be in excellent condition tread wise and no sign of weather checking) These are a economy tire and I will probably take a couple of runs with them this year yet, just a little concerned about my trailer rubber. The codes I found on the tires are as follows
008675 E4 (E4circled)
DOT UPOR
DJA1101
B 11B
19451 1
Can anybody decifer this? TIA
Old Sep 13, 2004 | 06:25 PM
DJ's Avatar
DJ
Do a google search for tire codes and you'll find all kinds of info. If I read that right your tires were made in the 11th week of 2001. I had a tire guy tell me once that there was no warrantee on tires after 3 years because of the higher rate of failure and that no tire should be used after 7 years.
Old Sep 14, 2004 | 09:56 AM
DSjockey's Avatar
Thanks DJ, I searched the Dean tire site and found nothing, did Google and found a lot but not what I was looking for, I'll be out and about today so I think I'll stop by a dealer and find out, I'll let you know if your right I've always heard from the RV crowd that 6 years was time to replace, with a off brand tire I'm not sure I want to push it that far though
Old Sep 14, 2004 | 06:51 PM
DSjockey's Avatar
Exactly correct sir, although all things considered I think I'll be replacing these next spring with some RIB's
Old Sep 15, 2004 | 12:18 PM
latitud_rt's Avatar
DOT UPOR means made in Findlay OH by Cooper Tire
DJA1101 is in deed 11th week of 2001 and DJA is an optional code used by Tire Development/marketing - pretty much means nothing to the consumer.
E4 circled means meets Economic Commision of Europe standards - in English - you can sell this tire in Europe (Netherlands)- technically called ECE. E2 would mean France. The number after the ECE mark are the numbers assigned by the body that governs the ECE. Each size will have a different number.
The other numbers are for plant identification, shipping, storage, tracking, etc...again, means nothing to the consumer.
Tim
truckin-on
19
May 12, 2010 04:34 PM
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
mrwaters
Dec 28, 2005 10:11 PM
