Prodigy Brake Control Help Please!!!!
Old Mar 30, 2004 | 07:32 PM
psajb's Avatar
Unhappy Prodigy Brake Control Help Please!!!!
Just installed the prodigy with the plug harness. My problem is that the controller does not show the trailer connected, but everything works fine the brakes, brake lights and turn signals. I do not get the digital reading (.C) to show that the trailer is connected. I digital reader just shows (.). When I try the manual button it shows (.NC).
NOTE: My truck did not come with the 7 pin connector from the factory. I paid the dealer to install the harness and hitch. Their is one wire from the harness that wasn't installed light blue. I questioned the dealer and they said that the wire wasn't supposed to be connected. So I tolk it to another dealer and they said it was installed right and show me the directions to prove it.
Any help is greatly appreciated,
thax pat
__________________
2003, 3500 ST 4X2 Qd, SRW, SWB, 48RE, 4.10 Limited Slip
Old Mar 30, 2004 | 08:14 PM
n5oxp's Avatar
This might help
https://www.dieseltruckresource.com/...ight=blue+wire
Old Mar 30, 2004 | 11:32 PM
SuperGewl's Avatar
The BLUE wire is the BRAKE wire to the trailer. Also check to see if they ran it thru the normal wires that should be there any way and check the 40amp fuse in the fuse box that is not installed due to NOT having the TT package.
Old Mar 31, 2004 | 07:57 AM
Hoss's Avatar
Thats MR Hoss to you buddy!
Re: Prodigy Brake Control Help Please!!!!
If you're referring to the blue wire dangling under your dash, they were correct. Connect that blue wire to the brake wire coming out of your Prodigy and your problem is solved. If your truck didn't come from the factory with the 7 pin plug (like mine didn't), then they run the brake wire for you but they don't hook it up to the harness. Simple fix. I'd just cut the blue brake wire coming from the Prodigy harness and splice it with that blue wire under your dash that isn't connected. That will fix your problem.
I had to do the same thing with my Jordan. The other two or three wires coming from the harness on the truck are connected, but the trailer brake wire is not.
Old Mar 31, 2004 | 08:07 AM
psajb's Avatar
Thanks all for the help!
I thought that I had brakes maybe I didn't and probley didn't. Used to tow with a 1500 I guess there is a big difference in braking with the 3500.
Thanks again for all your help!!
Old Mar 31, 2004 | 12:29 PM
FiverBob's Avatar
Hold a compass down by a wheel and have someone activate the controller. The compass will move if there is a field developed in the brake magnet.
Old Mar 31, 2004 | 07:19 PM
psajb's Avatar
Thanks again all for all the help it worked. But the blue wire does seem to be chinsey compared to the harness that came with the prodigy. I do not think that the blue wire is 12 gauge. I have a two axle trailer do you think I'll be all right?
thanks
Old Apr 1, 2004 | 08:16 AM
Hoss's Avatar
You are correct. For whatever reason, they used 14 gauge wire for the brake wire (I noticed the same thing). This bugs me to no end, but if you're not using more than four brakes (two axles) then the 14 gauge wire will work fine. If you ever pull a three axle trailer then you'll probably want to pull a new wire.
Old Apr 3, 2004 | 01:13 AM
Teddroe's Avatar
I just installed a 7 pin inside my box for my 5er. I went to the local rv store and told them I needed about 4 ft of 7 wire harness and a female plug. He brought out a 7 wire harness and all 7 wires were 14 ga wire. I asked him the same question and he went and checked with the guy in back. He came out and said that is the wire they use on all their installs and you will not have a problem with it. I test drove it and it works just fine.........
ajpulley
Jun 14, 2008 09:36 PM
BIGDAN65
Apr 20, 2008 06:44 PM
RSOPNCO1
Dec 1, 2007 03:08 PM
DCinTX
Jan 25, 2007 02:56 PM
jerryb
May 20, 2003 11:48 PM
