Power Tow Mirror Conversion
I'm currently in the middle of taking the 4 mirrors that I have apart. I was wondering if anyone knew of a place where I could get two new fastners with the tabs so I don't have to reuse the old ones. Thanks
Thanks, interesting think I have found out doing this conversion is Mopar has yet changed the design on the 94-02 mirror set. The once tapered design is now straight and now has 6 divit holes on the base so they can be held in the retracted position like the 03-05 tow mirrors which is making the conversion simplier but I am yet to take apart both drivers side mirrors.
Since you have done this same thing already do you have to do any type of grinding to remove a tab on the drivers side mirror? I just hope since they changed it for us that I won't have to do this. Thanks
does anyone remember the wiring? i have my mirrors ready to go back on but i cant get the power to work right. all i can get is left and right no up and down? i just snipped off the old wiring off my old mirrors and im trying to wire it up to the new mirrors but not having any luck!
I good thing to use is gator clips when trying to figure out the wiring. That is what I did on mine. Also, the two light blue wires I believe on the connector are both the common so you can use on or the other or both when you connect it to the dark green on the mirror. The blacks can connect to either one on the connector or the mirror. Hopefully that helps some. PM me if you need some more help.
Search for tow mirrors in the pics section. There are a couple members with the diagram. I did I guess I will have to ebay for a pre 05 mirror. Does anyone know how to tell by looking at the newer mirrors, if they are pre or post 05?
The newer mirrors, which is what I got and converted, has a more rounded mirror arm and the base is about 2 inches longer where it mates to the mirror.
cj5er
Dec 20, 2009 09:19 PM
hotdram
Dec 27, 2005 11:38 AM
