New to 3/4 Tons.....trailer/hitch question
Old Jul 28, 2006 | 05:00 PM
Ron Meadows's Avatar
I just hooked up our trailer to my new truck (06 Mega 4x4 w/ Cummins) and had to get another hitch shank due to this truck sitting up much higher than my old 1/2 ton. I redid all the calculations for my Equalizer weight distribution hitch and hooked her up. The end result is that the trailer is sitting within 1/2" of being perfectly level, the rear of the truck squatted by about 3/4", and the front remained at the same height as before hookup.
I guess my question is regarding the front end not dropping at all. Is this normal with a weight distribution hitch on a 3/4 ton? My old truck squatted on both ends a good bit with the trailer hooked up. Tongue weight of the trailer is about 750 lbs if that helps.
Thanks,
Ron
Old Jul 28, 2006 | 06:40 PM
SupaDupa's Avatar
That's probably the difference between towing with a 1/2 ton vs. a 3/4 or 1 ton!!! They've got a heavier frame, axles and suspension!!
Old Jul 28, 2006 | 06:47 PM
TxDiesel007's Avatar
That, as well as
factory overloads, and more springs (heavier duty as well) U cannot go wrong. Once u tow with a 3/4 ton or dually, ull never go back to a half ton, You now see part of the reason we love our trucks. (check out my pics to see what i tow)
Rick
Old Jul 28, 2006 | 07:54 PM
CrazyCooter's Avatar
Longer wheelbase would make a big difference in weight distribution.
Old Jul 29, 2006 | 08:50 PM
Pop-Pop's Avatar
I have an equalizer hitch (1000# bars). It took some doing but I was able to get the front end to drop about 1/2" & the rear 3/4". My hitch load is about 700#. While my truck can easily handle the trailer without WD or sway control, I recently gave it a real test by going up the Alaska highway. Having some weight on the front end is a big help when you get into the big dips and bouncy sections of roads.
Old Aug 5, 2006 | 10:17 AM
I just arrived home after pulling a little over 1100 miles in the mountains of West Virginia and Kentucky. I adjusted the sway bars and ended up with 1/4" rise in the front and 5/8" drop in the rear, resulting in the truck sitting dead level front to back. Other than my fuel mileage dropping to about 10.4 MPG for the entire trip I couldn't tell that the trailer was back there. This is a HUGE improvement over pulling with the half ton hemi. What used to be a white knuckle experience turned into a relaxing good time headin down the freeway at 70 MPH.
Thanks for the advise guys,
Ron
Old Aug 5, 2006 | 01:15 PM
Pop-Pop's Avatar
Good to hear the new truck did so well. I suggest that you set the load bars even tighter so that you get the front of the truck to come down at least 1/4". Until you do, you will not get the full benefits of the WD hitch. This will also help reduce longitudinal see-sawing when you hit certain uneven road surfaces.
Old Aug 6, 2006 | 01:47 PM
RickG's Avatar
I've seen the RV haulers tighten the chains on the hitch bars when the hitch just rested on the ball and before the truck dropped . They raised the jack after the chains were tightened . It makes things easier when you pull trailers with a different weight each pull .
89dieselkong
Dec 5, 2010 04:48 PM
Swamp_Donkey
Feb 6, 2005 04:52 AM
Tommy93w350
Jan 25, 2005 05:29 PM
dyp
Dec 6, 2004 01:32 PM
doomgaze
0
Oct 8, 2004 10:35 AM
