need help with decision on trailer and weights
Old Nov 5, 2007 | 09:11 PM
fng120's Avatar
hey guys,
need some help here. wanting to upgrade to a fifth wheel and cant decide if i will be over weight. i am looking at 2 different models the heartland sundance 2997bhs with a hitch weight of 1675 and gvwr of 11870 and also the heartland big country 3490bhs w/ hitch weight of 2121 and gvwr of 14000. i have a 07 2500 mega cab with 5.9 and g56 4x4 with 295/70/17 terra grapplers tires are load range d rated at 3415 lbs @ 65 psi . any opinions or input would help out alot. thank you in advance for your help
Old Nov 6, 2007 | 11:10 AM
PaulDaisy's Avatar
I don't see how you would have a problem with either one but I would imagine the larger one would be more of a handful. A dually would be more suitable for a large unit like that, although your rig would make it too.
-P
Old Nov 6, 2007 | 11:48 AM
haulin-rv's Avatar
I would have no issues towing either one, but with that being said I am sure someone from the weight police will come up with a calculation saying they are too heavy.
Old Nov 6, 2007 | 08:51 PM
MikeRP's Avatar
The pin weight is a little high on the second one from my research. You may have to add air bags. Also, the dually dudes have no issues but I think it can happen you probably however should check with the dealer and the RV seller.
Also I have the usuall disclaimers that hauling overweight may cause injury or death as well as indegistion.
Rednecktastic
Nov 14, 2007 09:18 PM
Spooler
Oct 6, 2006 09:43 AM
cshoem286
Nov 5, 2005 06:56 PM
Crashking
Jul 25, 2005 07:58 PM
Mexstan
Feb 8, 2005 03:47 AM
