Need help with 7 pin wiring.
Old Apr 16, 2006 | 08:23 PM
rjjr's Avatar
I need to have a seven pin connector in the bed of the truck to connect my gooseneck trailer to.
I've taken the factory 7 pin connection apart to determine which color wire goes to what function but it's impossible to tell from the connectors on the back side.
I searched the forums and found some information but isn't applicable to my truck. Mine is a 2006.
Can anyone help with the wire colors?
Old Apr 16, 2006 | 09:00 PM
bikeboy1713's Avatar
Here are some wiring diagrams that should put you on the right track
http://www.etrailer.com/faq/wiring.asp
Old Apr 16, 2006 | 09:31 PM
rjjr's Avatar
Thanks for the link. Already tried that one. They must have changed things for 2006.
Old Apr 16, 2006 | 09:50 PM
99 cummins's Avatar
Just turn things on one at a time and test the wires in the back of your current plug to see what colors are what.
Old Apr 17, 2006 | 01:18 PM
belltech64's Avatar
on my06, the 7 pin flip down cover has the schematic of what pin does what.
Old Apr 17, 2006 | 04:16 PM
driver612's Avatar
mine too
Old Apr 19, 2006 | 11:15 AM
alMout's Avatar
This is for an 04, not sure if same for 06
RT - Lite Green
LT - Yellow
Running - Brown
BU Lamp - WT/LG
Aux - RD/VT
Brake - Dark green
Ground - black
Old Apr 19, 2006 | 11:46 AM
Patrick Campbell's Avatar
Keep in mind depending on how you look at it, it might be opposite or backwards from looking at the rear vs looking at the front. Thats why they have the car end and trailer end diagrams. This is pretty standard and I don't think they would change the functions in terms of location, but they might very well change the wiring colors.
gsmopar
Aug 18, 2009 11:10 AM
Equalizer 2
Mar 10, 2008 10:26 PM
strean
Sep 13, 2006 03:54 PM
Grumpy
Jan 11, 2005 10:48 AM
Stevenc
Nov 21, 2003 09:05 AM
