My 14K trailer came with 12K worth of tire
Originally posted by RustyJC
In our case, we replaced the tires with LT235/85R-16E Michelin XPS Ribs - an all steel construction radial recommended by Michelin for commercial trailer service. I've never heard of a failure of an XPS in 5th wheel service, and they run much cooler than the Goodyears.Rusty
That's correct. The Goodyear Wrangler HT has a fabric carcass with steel tread belts. The Michelin XPS Rib is all steel construction. You can get more information HERE.
Rusty
Rusty
I'll have to go to the RV storage facility and see. I wouldn't doubt the all-steel construction claim - that's standard fare with commercial tires. You can also check out the Goodyear G159 series (used to be the G614, I think) - it's an all-steel construction commercial-type tire that's available up to load range G in 16" sizes, I believe.
Rusty
Rusty
Originally posted by roadranger
This is a common problem with 5th wheel RV's.
They put cheap 15 in. tires on a unit rated for WAY over the tires' carrying capacity.
Many 5er owners are having to upgrade to 16 in. rubber at their own expence to avoid the inevitable blowouts.
Hi fellas,I thought I'd chime in here on the trailer weight ratings as they applied in Manitoba and Saskatchewan,Canada. I was a Rainbow Trailer(utility,flatdecks,goosenecks,etc.) dealer in Sask. for 6 years, and when I first started getting my trailers,the plate on the trailer was the same as the axle rating,even if the tires didn't add up to that max. weight. Then the Trasportation Board stepped in and forced the manufacturer to change the max. wt. rating to match the maximum of the tires. If the tires were rated higher than the axles,then the axle rating was again allowed on the tag. Bottom line,is no matter what the tag says, you can't overload the capacity of the tires.The mfg. then started using Marathon trailer radials on all of their trailers, and the problem was solved...but for a period of time, they had to de-rate their trailers.....rules may be different in other jurisdictions. Hope I wasn't rambling on...Mark.
OK, here's the sidewall information off the Michelin XPS Ribs:
Tread - 4 steel plies
Sidewall - 1 steel ply
Rusty
Rusty
I wonder if they can be plugged if one picks up a nail or a screw? Nat
getblown5.9
Mar 16, 2007 08:17 AM
