Max Load on Stock QC
Old Oct 8, 2009 | 10:39 PM
tysrsx1's Avatar
Can I get away with hauling 2000/2500 lbs in the bed of my stock 07 QC?
Old Oct 8, 2009 | 10:51 PM
2500Ram's Avatar
Assuming you have a 2500 and not a 3500 either way I say fine.
I get a few pallets of wood pellets a year to burn, 2000lb per pallet and I barely hit the helper springs with 2k in the bed.
Old Oct 8, 2009 | 11:00 PM
tysrsx1's Avatar
yea 2500, for some reason my signature is gone that says that...anyway its still got stock tires only traveling about 100mi.
Old Oct 8, 2009 | 11:05 PM
03RAMBUNCTIOUS's Avatar
I watch wind blow...
it will ride like a Cadillac . . Do a search on here about a concrete bed liner. . . haha.
2k will be just fine.
Old Oct 8, 2009 | 11:36 PM
raymond21's Avatar
Is it time to dredge that one up again already?
https://www.dieseltruckresource.com/...k-t42441.html?
As far as the original question, I subject my '03 to those kind of loads quiet frequently, no problem.
Old Oct 9, 2009 | 06:37 PM
Dodgezilla's Avatar
Well, the truck can definitely handle it BUT I know my truck would definitely be sitting on the overloads with just one 2000lb skid in the back. Now that I added Timbrens I have no worries and the truck does not squat at all...
Old Oct 9, 2009 | 08:22 PM
tysrsx1's Avatar
Ok so here is the low down. I tried it out this morning. The actual weight of the skid was 2400# which consisted of misc. fabricated and machined parts from my shop. I set the weight right over the rear axle as far forward as possible without removing the toolbox. As I lowered the forks on the lift I was not sure if the truck was ever going to stop sagging, once it did I was resting about 5 inches above the bump stops and there was noticable misbalance from front to back. So being that this is my brand new baby, I decided to re-evaluate my setup/ capacity before getting too carried away. Are some airbags in my future??? Hmmm...
Old Oct 10, 2009 | 09:04 PM
jlipskoc's Avatar
Why not use a trailer, or rent a 16ft'er dual axle? I personally like the wear and tear on something other than a nice truck.
Old Oct 15, 2009 | 07:59 PM
as a matter of fact it is. . .
back to the subject, I have to go pick up two pallets of grain for the live stock tomorrow. If I had a long bed I would have NO problem loading it into the bed. But I do not so I will drag the little trailer out. But I am only going across town.
I have seen a guy with a 500 gallon water tank and a pump and a metal frame for all that in his short bed. squats it a bit.
Firstgenfanatic
Apr 10, 2008 12:24 PM
carwash
Sep 12, 2007 11:39 AM
cumminsdriver635
Aug 8, 2005 05:46 PM
1big44
Jul 30, 2003 07:00 PM
eng208
Jul 3, 2003 08:44 PM
