Lift Pump for peace of mind
I have a slightly mod'd 2003 CTD (see sig) with 103,000 miles on the original lift pump. It's on the fuel filter and working fine.
Question. For extra insurance, should I:
1. Go with advice in Turbo Diesel Register 56 article: KISS principle...Buy a spare Cummins lift pump. It was sufficient for for all boxes tested (100HP and below). COST: $180 and I've got backup I can put in on the side of the road.
2. Go with a FASS 150-1003 pump. Have the ultimate deliver at a rock steady 15-17psi. Cost: $430 + 225 to install and I've got no backup on the side of the road.
Thoughts, I'm leaning toward #1. I never go above #5 on the Smarty SR (90HP) and the stock pump performs just fine. Is replacing it with a good tool kit a "side of the road" job or am I kidding myself.
you could also do a walbro setup if you can find one. would be cost effective if you diy
then any quality car parts store will have a walbro pump on stock most of the time.
or just buy 2 pumps at first since they are 99 bucks or less.
most walbro pumps will last 100k plus at 45psi in a car.....at 20psi it should last a long long time.
Thanks for the ideas. Found a great link on an airdog install.
http://www.cumminsforum.com/forum/ac...tallation.html
I'm still leaning toward just carrying the spare OEM replacement pump. Why: $400+ for the airdog and I've got no spare (2 is 1 and 1 is none).
Still looking at the Walbro idea. Is there a specific Walbro pump number I can google?
No one seems to like the idea of just keeping a stock pump on hand as a spare?
Are all these aftermarket pumps (Holley, Fass, Airdog, Walbro) that much more reliable? I'll pay for reliability/performance if someone quantifies how much more reliable/better performance I could expect.
My stock pump has gone over 100K, delivered the fuel and a spare is only 4 bolts to swam and $187. Am I being shortsighted?
Decided to order an Air Dog 100.
I will keep the stock pump and all lines in place and unplug pwr supply. Then I can switch back, should the Air Dog ever go.
Seems like a pretty easy way to have a backup. Anyone see where this would cause any problems?
Brad
Brad
The disadvantage of a spare stock one is that they are hard to put in and they are a poor design.
If you run a Glacier setup with a Walbro pump you can change it out in minutes with another Walbro or with any cheap 12 volt pump from any parts store in minutes. I carry a cheap replacement that cost about $10.
On the '03 and '04 you don't have to get into the tank at all. The pumps are quiet and not some proprietary setup that will require a special order if you have trouble. Plus the Walbro is far cheaper.
If you want better filtration than stock you can always add a spin on 2 micron setup and easily get replacement cartriges.
