king pin goose neck plate
Old Feb 2, 2009 | 10:23 AM
freds89's Avatar
I bought an 1989 d250 from a plumbing supply company and it has a Goosneck plate in the bed. Well I fliped it up once I got home and found it was a king pin like the one that is on a otr trailer they had a trailer that hooked up to the truck. I was wondering what I can do with what I have? I looked at it for a little and it didnt seem like I could thread the kingpin off and replace with a ball for a regular goose neck it loooks like I would need a whole different plate to make it work and i looked at the plate it is welded to the frame on the inside and outside of the frame. I dont have a trailer at the moment but eventualy I want to get a goose neck trailer. Rite now that kingpin is useless unless I flip the truck upside down and lock it into a otr tractor 5th wheel
Old Feb 2, 2009 | 12:19 PM
rich's Avatar
try to get some pictures to help give us some ideas, cut the kingpin off maybe and install ball
Old Feb 2, 2009 | 06:56 PM
olddodgetrucks's Avatar
some trailers where inverted 5th wheel,the hitch was mounted on the trailer not on the truck
Old Feb 2, 2009 | 08:15 PM
Tobin's Avatar
Does it look like this:
http://www.tandrtrailer.com/media/im...pl/kingpin.jpg
Curious as I have seen this before and not seen the trailer side of what attaches to it.
Tobin
Old Feb 2, 2009 | 08:21 PM
freds89's Avatar
ya it looks like that link ill try to get some pics of it
Old Feb 2, 2009 | 10:30 PM
Bluedually4x4's Avatar
We have that same set up at work on our F-350, and they use the same inverted system on some oil field trucks. I guess the only real nice thing is you don't have the 5th wheel taking up space in the bed.
Old Feb 3, 2009 | 07:59 AM
RAMRODD's Avatar
When you buy a trailer you don't have to go with a ball, you can go with a kingpin. Or if you find a used trailer the inner tube that you adjust for height just slide it you and replace with a kingpin one. They run around $200
leroy
40
Dec 10, 2004 05:02 AM
KATOOM
Feb 2, 2004 01:56 PM
Sittenbull2
Jun 10, 2003 12:34 PM
kamper
Mar 29, 2003 10:13 PM
USMC64-70
Dec 22, 2002 08:07 PM
