i think i killed my trailer
Old Sep 8, 2008 | 01:07 PM
whitebuffalo's Avatar
i've been moving the past week and hauling all my junk over to the new place. well, heading to pick up a load and i noticed one of my trailer tires wobbling like a drunk politician. so, low and behold, it looks like the outer bearing went tango uniform. the problem is, it scored the underside of the spindle towards where the inside bearing goes. i'm sure i know the answer to this, but, just sticking new bearings in there wont cut it, right? its gonna have to be a new axle?
anyone have any ideas of where to pick up an axle or two for fairly cheap? pricing them on trailerpart.com, it looks like more than i can really drop right now, post move and all that.
the saving grace is, at least the stuf is 95% moved before it happened.
Old Sep 8, 2008 | 01:30 PM
Lil Dog's Avatar
It may be repairable at a local axle shop by just cutting that end of the tube off and putting on a new spindle. Not sure on that cost, it may be cheaper to go with a whole new axle..??
Old Sep 8, 2008 | 02:46 PM
TonyB's Avatar
See if you can find an "Auto Safety House" in your nearest town/city. A truck store may also be able to supply one.
Here, Auto Safety House have 3500lb axles for ~$130. That's what we used to replace the axle under my bro's boat trailer.
Tony
Old Sep 8, 2008 | 03:20 PM
crobtex's Avatar
Happened to my SIL's trailer a few years ago. Went to Northern Tools and picked one up....don't remember the price, but it was reasonable for a complete axle.
http://www.northerntool.com/webapp/w...+166843+775719
Old Sep 8, 2008 | 03:39 PM
Jeff in TD's Avatar
How "scored" is the underside of the spindle?
If it is just scuffed up and hasn't changed shape in a way that effects how it contacts the inner races of the bearings, maybe it could be dressed up?
On the other hand, if it is really chewed up, a good trailer shop should be able to weld on a new spindle and keep things aligned properly.
Old Sep 8, 2008 | 09:05 PM
Colo_River_Ram's Avatar
With age comes the cage
Whats size of axle are we talking here? Check in the phone book under machine shops and look for someone who is set up to Flame Spray they build it up and machine it down to factory specs.. most HD mechanic shops would know of the people set up to do it.
Old Sep 8, 2008 | 09:38 PM
tool's Avatar
The other thing to remember is, if the bearing is pooched that hub/ spindle has likely been VERY hot. I've seen the inner races actually welded to the spindle.
The heat created from the bearing running dry and/or failing can cause that spindle to loose the temper that has been hardened into that steel which can allow that spindle to bend or break. Not something you want to have happen.
If the spindle is scored than the inner bearing race has obviously grabbed and spun on that spindle.
As allready mentioned spinndle or axle replacement might be the best option.
I had 6,000# axles custom made for approximately $160 this spring, I would think that is money well spent.
I would look into that.
Old Sep 9, 2008 | 12:35 PM
where did you have that done? most of the 6k axles i've been finding with brakes were $400 and up.
Old Sep 9, 2008 | 09:52 PM
rich's Avatar
their 2 trailer places in s a one is down on 35 south by past 90 and the other is southwest trailer and wheel i think
Old Sep 9, 2008 | 10:49 PM
Pull Ya's Avatar
Don't go to Magnum here in Austin or anywhere else. You won't even get a kiss after they **** you
Old Sep 10, 2008 | 10:24 AM
tool's Avatar
Local axle and spring shop that builds axles.
I just bought the tubes and swapped my brake and hub assemblys over.
Nov 30, 2008 05:46 PM
dzl_damon
Jun 16, 2008 11:20 AM
RyeThomas
Jul 11, 2007 04:31 PM
IA_James
Oct 23, 2006 10:20 PM
CUMMINSBILL
Jun 6, 2003 10:02 AM
