I need my 5th wheels hitch installed ASAP, and I need help!!!
Old Sep 22, 2008 | 09:47 PM
stock03's Avatar
Exclamation I need my 5th wheels hitch installed ASAP, and I need help!!!
Does anyone have any pictures or specific details regarding the installation of a Reese 15k slider hitch? Pictures would be great too. I just got mine today, and the instructions don’t seem very clear. I plan on going camping this Friday and need the hitch installed before then.
Thanks for any and all help!
Old Sep 23, 2008 | 07:12 AM
1-2-3's Avatar
Just a plain ole guy
What part do you not understand? Do you have the rails mounted in the bed of the truck yet?
Old Sep 23, 2008 | 07:59 AM
CTD NUT's Avatar
Are you using the universal rail mounting kit?
Old Sep 23, 2008 | 10:24 AM
1-2-3's Avatar
Looks like an 03 will need a kit like this.
http://www.etrailer.com/p-50040-6008.htm
It's a clamp on kit that goes over the frame rails. Once that is installed, you drill holes through the floor of the bed to mate with the tabs in the mount brackets. The long bars (bed rails) will bolt through the bed to the frame clamp brackets.
The hitch head will need to be assembled, and then it will sit on the rails and will be held in place with pins.
Once it's installed, you will need to do a combination of adjusting the hitch and pin box heights to insure your trailer is being pulled as level as possible AND that you have enough bed clearence. You don't want to smash your tailgate against the bottom of the trailer as you pass over humps.
Also, take your wrenches with you and stop occasionally and make sure all the bolts stay tight.
Old Sep 23, 2008 | 11:13 AM
1-2-3's Avatar
You may be ok with an 03 as far as the wiring goes. if you have the trailer package allready, you should have thge 7 way plug by the license plate bracket, and most pigtails will reach.
Do you have an electric brake controller?
Old Sep 24, 2008 | 11:48 PM
stock03's Avatar
Hey guys, thanks for the responses. I think I was just not understanding where the brackets went. I finally understand them. I now have the rear brackets mounted, and they’re even. The match up with the front rail too. However, the brackets for the front rail are not flush with the frame. They’re each off about ¼ inch. Can I use spacers for the front brackets? Once the front brackets are installed, I’m finished and can tow my new (to me) 5th wheel this weekend. Again, thanks for all the help. Also, I wish I would have purchased the kit you mentioned, 1-2-3. I hate drilling through my frame!
Old Sep 26, 2008 | 06:02 PM
stock03's Avatar
Ok, my hitch is in, and it tows great. The instructions that came with my Reese hitch say, "These instructions are guidelines only..." I finally mounted the front rail the same way as a Chevy (saccording to the directions) should be mounted. Everything fits great now!
Old Sep 28, 2008 | 10:06 PM
1-2-3's Avatar
How did you end up mounting your bed rails to the frame? I got the kit I mentioned installed this weekend and it went fairly well. it too had the guidelines clause in the instructions. it gave demensions only to the front bed rail so we set the hitch in after the front rail was mounted and let it be the guide. That relly worked out well. The instructions actually placed the hitch 1.5 inches in front of the rear axle. I was kinda hesitent to do this and almost adjusted it to be directly centered over the axle, but when we mapped out all the holes on the bottom side, directly over would have put bolts right into a shock mount.
I tried the trailer with it this morning and it was all just fine.
Old Sep 30, 2008 | 09:03 PM
stock03's Avatar
My hitch is about an inch or so in front of the axle too. I finshed the install Friday and went on a camping trip Saturday. It towed great, and the trailer didn't fall off. So I guess I did ok. Next time I install a 5th wheel hitch, it wont take 4 days.
charger7022
Jul 5, 2010 08:29 PM
440727
May 14, 2010 05:06 PM
checkster
Jan 19, 2010 09:30 PM
bluebull
Apr 5, 2005 06:43 PM
