how many have a second air tranny cooler installed?
Old Feb 2, 2004 | 06:35 PM
vtailflyer's Avatar
Hi everyone,
I am planning on pulling a 5-6000 lb 5th wheel with my 2WD dodge cummins. I have been looking at adding an additional tranny cooler after the factory cooler up front.
Is an additonal cooler required? or does the factory one perform OK? I don't want to fry a tranny due to to high a temp.
what kind of temps can I expect with the factory cooler? I live just west of the rocky mountains and will most likely be towing through them at times.
thanks
Brian
Old Feb 2, 2004 | 07:58 PM
pappyman's Avatar
To me that kind of load is an empty trailer....the cooler works petty good.....y dont you install a tranny temp gauge first to see what kind of temps your running at.....be sure to put the temp sensor in the out line at the point of the hottest fluid temps
Old Feb 2, 2004 | 09:46 PM
ten8fiftyone's Avatar
I agree with pappy, that's a pretty light load for the Cummins. And the passes in your neck of the woods are not nosebleeders like Colorado. I towed 8k regularly in the Colorado Rockies with an 01 1/2 ton gasser using the stock tranny cooler. Never had a problem. I just didn't let the tranny hunt when pulling and I changed the fluid more often.
Old Feb 3, 2004 | 03:57 PM
Junk Yard Dog's Avatar
Brian, you should at least have a temp gauge, but the second cooler would not hurt either. All my auto's have the second cooler as a 18,000#, and some of those trucks the fluid would hit 195*.
Rick
Old Feb 3, 2004 | 08:40 PM
vtailflyer's Avatar
I'm putting in a tranny temp gauge on the oulet line to the firdt coolant/tranny exchanger. I am also going to install a pressure sender in the same line to monitor TC lockup psi. I'm also putting another sender to monitor tranny line pressure.
I will pass on the cooler and see how it does.
thanks everyone
Old Feb 4, 2004 | 06:08 AM
SuperGewl's Avatar
You know, I agree with everyone else, pulling a 5-6k trailer is like going around empty, that is unless it's BIG Like a barn door BIG
I pulled a 21ft TT accross the country in the summer, it stood about 12' tall and had know problem pulling it running at highway speeds with the cruise set and AC kicking, all stock except for fliuds.
Don't worry about it, just Drive it Like You Stole It
Old Feb 4, 2004 | 02:44 PM
SBishop's Avatar
I don't think you will need the extra tranny cooler. I pulled our 27ft 5er all thru Arizona this summer in 100+ degrees and never had a problem.
Tank_66
Jan 11, 2012 10:12 AM
Timberman
32
Aug 26, 2010 05:54 PM
powermad
Jun 22, 2008 09:16 PM
BIGHEAD
Jul 24, 2006 07:49 PM
