Gooseneck question
Old Sep 30, 2007 | 06:25 PM
$oC@l CTD's Avatar
Gooseneck question
I have a shortbed...Gooseneck work back there? it would be used for a toy hauler, for our cattle haulers and for an equipment hauler. My father has a shortbed 2nd Gen, but he does everything 5th wheel...I prefer gooseneck because they are rated higher. Sure, they are a little harder to get hooked up, but when you are possibly hooking up to 26K backhoe/trailer combos, I would prefer to have the gooseneck...thanks
Old Sep 30, 2007 | 07:42 PM
bigdave's Avatar
A gooseneck will work fine.
Old Sep 30, 2007 | 07:49 PM
TNContractor's Avatar
I have a B & W in mine. Works fine, just watch sharp turns with square nosed trailers.
Old Sep 30, 2007 | 10:12 PM
mj007's Avatar
Works for me
Old Sep 30, 2007 | 10:20 PM
rip 112's Avatar
^^^^^^I agree. I run a drawtite rail hitch with a gooseneck adapter, no problems at all.
Old Oct 1, 2007 | 07:50 AM
durasmack's Avatar
It will be fine. There are two options if a regular gooseneck doesnt allow you enough room. B&W makes an offset hitch for their hitch, and there are also various different slider hitches available. If you buy a slider type 5th wheel, that would also be more likely to be what you need for a toy hauler. You can always switch your other trailers necks out to 5th wheel or buy an adapter plate to set on the top of the 5th wheel hitch.
metalmellinium
Dec 9, 2007 11:16 PM
clarson80
Dec 6, 2007 05:02 PM
HolyRoller
Oct 22, 2007 10:45 AM
gdh11
Aug 19, 2004 09:01 PM
MrBilly
Oct 21, 2002 09:37 PM
