Good Shock
Old Dec 16, 2007 | 08:18 PM
GEJim's Avatar
Good Shock
Need some advice on rear shocks. 05 Quad cab 2500 5.9 engine. I am looking for a good shock to improve the unloaded ride but at the same time help take some of the chucking out when I pull my 5th wheel. Any ideas?
Old Dec 16, 2007 | 08:20 PM
rustyshakelford's Avatar
bilsteins will more than likely be the most common answer
brett
Old Dec 17, 2007 | 08:48 AM
oldracr4L's Avatar
4 new Bilstein shocks made a night and day difference in pulling a 11k tag, or 16k 5th wheel. They were a little stiff at first (unloaded), but now they work great loaded or empty. You may need a Mor/ryde pin box on your trailer to help with the chucking.
Old Dec 17, 2007 | 10:04 PM
dadwolf2's Avatar
Bilsteins and check out Demco's glide ride system:
The Glide Ride:
* Absorbs bumps and jolts through a gravity, self-centering parallel linkage system.
* Greatly reduces stress and fatigue at the hitch point.
* Maintenance Free.
* Doesn't effect braking or steering.
* Helps prolong the life of your truck and RV.
* Makes a smoother more pleasant ride.
* Up to 21,000 lbs. G.V.W.R.
* Models available for many popular late model fifth-wheel trailers.
* Call Demco for the proper application.
List Price $739.00
Old Dec 17, 2007 | 11:29 PM
stumpjumper's Avatar
ditto on the bilstein's- www.shockwarehouse.com also check out www.fifthairbourne.com for a cushioned pinbox. if you have a short bed they also have a pin box to work with shortbeds called the "sidewinder".
Old Dec 17, 2007 | 11:30 PM
also we put monroe shocks on the trailer. part number 555025 also from shockwarehouse. these helped tremendously on the trailer.
Old Dec 17, 2007 | 11:32 PM
sorry that's www.fifthairborne.com
Old Dec 18, 2007 | 12:02 AM
SundayMoney's Avatar
Bilsteins for all 4 corners. Why just replace the rears?
I had Rancho 9000s on my 2500HD and they worked great. After about 2 weeks of "adjusting" them I decided I liked them maxed out as firm as they went. I didn't adjust them a single time after that.
I'm going Bilsteins this time.
Old Dec 18, 2007 | 12:21 PM
supr's Avatar
Bilsteins are the single best mod you can do to these trucks. Ride differrence is huge. Buy 4, be happy!
The OEM shocks are good from the dealer until you get home.
Old Dec 18, 2007 | 08:02 PM
GEJim's Avatar
Good stuff, thanks. Bilsteins are on order (Allshocks.com) $67.95 each, free shipping.
Old Dec 22, 2007 | 05:45 PM
Casey Balvert's Avatar
Bilsteins are the way to go. I installed four of them this spring and it did improve the ride especially while towing.
Casey
Old Dec 28, 2007 | 12:10 PM
theextricator's Avatar
Bilstines all the way!!! All four for my 2005 2500 CTD from Shockwarehouse.com $258.21 delivered to my door!
Old Dec 29, 2007 | 03:40 PM
beretzs's Avatar
I just added Bilstein 5100's to the truck. Can't really tell too much of a difference unloaded, but they do really work with the 5th wheel on the back. Money well spent. Scotty
freight train
22
Mar 25, 2013 04:46 PM
stumpjumper
Aug 21, 2007 07:14 AM
j
Nov 10, 2002 10:40 AM
bkay
Nov 1, 2002 10:18 AM
Huey
Oct 27, 2002 12:58 PM
