Good Brake Controllers
What are some of the better trailer brake controllers out there. (no money for Dr Performance so don't bother with that one) The one I have now will display how much power it delivers (and adjusts that) to the brakes but it will not adjust how it uses the power, so I have stops that just easing to a stop I have full power to the brakes.
For the dollars you can't beat the Jordan Ultima. The brake pressure to the trailer is regulated by a sensing wire on the brake pedal. It brakes exactly as much as you push the pedal. No jerks, no erratic behaviour. Runs around $130 MSR. There is a new model coming out in about March that is supposed to be even better. If you can wait, I sure would.
Bob
Bob
I use a RedLine variable rate controller and I love it. Smooth stops for the horses... easy to install and compared to many of the others fairly economical.
easy to hook up as well......and I trust Redline since they manufactor a large majority of the trailer brake assymblies out there.
http://www.redline-parts.com/pdf2/El...s%20051205.pdf
If you can't afford a Brakesmart and can't wait for a Jordan, Prodigy is the next best choice. Once you use either a BrakeSmart or Jordan, you won't want to go back to the Prodigy.
