Exhaust brake causing motor to stall
Anyone else with a manual trany have this happen with a fueing box adding more fuel to the motor? In a panic stop pushing in the brake and clutch at the same time to grab another gear with the exhaust brake on the motor will die off. Obviously in regular driving conditions you can rev the motor while between gears or just turn the brake off butt......
Wondering if anyone else has had this happen.
Thanks
Thanks
There is a good possibility that your exhaust brake is just choking the motor off and killing it. It takes a very minor adjustment to make a huge difference in braking power. I'm tempted to say yours is a little "tight" in the adjustment area.
I don't know if you run a brake pressure gauge but it really helps in diagnosing problems when it comes to these things. At idle, with my BD brake anyways, I shouldn't have more than 20-25 lbs of back pressure when the brake is on. Any more and the motor will start to chug and eventually die.
Hope it helps
Jeff
Hope it helps
Jeff
i never set anything, but i will look into it. with my fueling box turned off it doesnt do it at all. so thats why i think its just the extra fuel causing it.....
Right. it works fine and idles normally with the brake on. Its when a quick stop is had it just seems to choke the motor. Maybe choke isnt correct, more, to much back pressure with the added fuel from the box and it will bounce down to 500 rpms etc.. and sometimes die and sometimes not. just depends.
back pressure gauge
I put one on the truck in my sig. There should be a threaded plug on the pac-brake exhaust elbow on the top. I used a 1/8" copper tube line from the plug for about 18" to handle the heat and then used a poly line to run into the cab. I bought a cheap air pressure gauge that I have in the cab. It rattles a bit, but at least I know what kind of back pressure I have. (If the cheap gauge is accurate). This copper line does break occasionally from the vibration of mighty cummins.
Stan, currently in Pratt, KS.
flyingd
17
Jul 11, 2017 11:13 AM
StevenAg03
Jul 27, 2009 12:24 AM
RockysInMyBlood
0
Jun 18, 2009 03:14 PM
jrussell
May 31, 2007 12:33 PM
JD730
Aug 2, 2005 11:33 AM
