Driving lights aren't working on trailer...
I've hooked 3 different trailers up to my truck and the driving lights aren't working on any of them. They used to so I'm assuming it's a fuse? Can someone point me in the right direction on which fuse to look for? The brake lights and turn signals work fine, just the driving lights.
Thanks.
Thanks.
I'm not fully up to speed on all of the stuff on the 3rd gens, but don't the '06s have the TIPM (Totally Integrated Power Module) instead of fuses for the trailer lights? If so, I believe it requires a reset (possibly dealer) if it has been tripped.
Have you checked your plug at the back to see if you have power on the pin for the trailer lights?
mine did the same thing, 05, under the hood is the fuse panel, number 33 is the trailor running lights. I checked it and it was blown. 20amp. fuse. I used a test light to check the power at the hook up and I have power there but the lights on the trailor still didn't work, just the running lights all others worked. Not sure if it's the trailor or somthing else with the truck. Gunna hook up to another trailor tonight to see whats up.
my trailor running lights quit also no bad fuses and the taillights on the truck work fine no juice on the 7 way or the 4 flat for the running lights..hooked to buddies 05 and evrything works fine,,my truck is 06.5 ctd 2500 auto 4wd everything else on my trailor works fine just no running lights Did you find your problem?? mine sounds like the same as yours Thanks Ron
TIPM,been there it needs a reset. I think it can only be reset either 3 or 5 times,and then has to be replaced. about $300 I think. there is a reprogram boosting the current from 15 to 17.5. I had that done and haven't had any problems since. they blame it on faulty trailer wiring always.
Mopar_Mudder
May 18, 2003 04:57 AM
