Driveshaft wall thickness?
Old Aug 27, 2009 | 04:19 PM
Billut's Avatar
I have installed a NV4500 and GV under/overdrive on a 92 W350 and am about to get the driveshaft made by a shop. Was just wondering if it makes any sense in having the wall beefed up some? I tow lumber on gooseneck 10-ton trailer. What are your thoughts?
Thanks!
Old Aug 27, 2009 | 11:03 PM
PChouinard's Avatar
Hmmmm. I'm not an expert in drivetrains but i would assume a thicker wall would make for more rotating mass and would be harder to balance. Is there a chance of using stronger material?
Old Aug 29, 2009 | 08:02 AM
Billut's Avatar
valid point, I'll ask the driveshaft shop people for their take
Old Aug 29, 2009 | 04:30 PM
RPegram's Avatar
I've seen quite a few driveshafts twisted like a pretzel, but all were caused by snatching, dumping clutch or speed shifting. All of these put a tremendous sudden amount of pressure which will twist most any shaft. As long as you shift like you should and don't dump the clutch like you are at the drag strip while towing a heavy load you should be fine with the stock shaft.
Billut
Aug 26, 2009 07:50 AM
hotdram
Sep 11, 2004 09:26 PM
KATOOM
Apr 7, 2004 12:12 AM
FastSS
Dec 2, 2003 07:57 AM
