d vs e tires
Old Apr 15, 2010 | 04:15 AM
kingofdodge7131's Avatar
d vs e tires
Hey guys lookin at some newtires because..... the load D range bfg all terrains i have lasted some 8000 with my trailer, its heavy yes, actually right at the tires limit, ( i have a 2500 with a rear axle weight of 5900)
Being the load e and D have the same weight capacity, do the 10 plys last longer?
Old Apr 15, 2010 | 08:32 AM
2006Mega's Avatar
i don't know if they last longer but at least im my case the truck doesnt move around as much with our 5er in tow. i am also right at my rear axle limit, in fact if i don't empty my tanks i am over by around 200 lbs.
Old Apr 15, 2010 | 09:04 AM
Rare1's Avatar
Even though they have the same load capacity, an E tire is much less likely to be destroyed by the same load as a D tire. An E tire is much more durable.
Old Apr 15, 2010 | 10:31 AM
cmac's Avatar
if you took two tires of the same brand and size, one load range d and the other an e, the load range e will last longer and provide more stability over the load range d tire.
Old Apr 15, 2010 | 11:30 AM
Scotty's Avatar
Top's Younger Twin
If I recall this correctly the sidewall strength is the difference. So that should correlate with stability and longevity. Never used a ' D ' rated tired so cannot comment from personal use.
Scotty
Old Apr 15, 2010 | 01:28 PM
annabelle's Avatar
If they only lasted 8,000 miles, something was wrong. The E rated tire is much more stabile. I've gotten as much as 80,000 miles out of mine, and had legal tread deapth left.
Old Apr 15, 2010 | 03:23 PM
15 Digger's Avatar
More plies, less flex means less heat and safer for loads and longer life. When empty will ride harder so use less pressure when empty. And If your truck calls for E rated tires and your in an accident because of tire failure I would be worried about Liability.
Old Apr 15, 2010 | 04:58 PM
I had a smaller set on my 04 and got a ton as well, i was a little disapointed, maybe my rear axle is outa shape, i know when i hit gravel its all squirly, but its fine on concrete
chrisminx
14
Jul 7, 2010 06:48 PM
1320
May 29, 2009 10:24 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
Captain
Sep 9, 2005 12:16 AM
